8 Replies Latest reply on Oct 3, 2007 12:44 PM by Newsgroup_User
    Exporting images withOUT rollover frames?
    Level 7
      Small pet peeve that I'm hoping is fixed by some preference
      setting...whenever I do a layout for export, I usually have a handful of
      images that will have rollovers, and a whole bunch that won't.
      However, when I export, ALL the images end up with rollover/_f2
      images...even those that aren't explicitely set with a behavior. Is there a
      way to turn that option off?
      -Darrel
        • 1. Re: Exporting images withOUT rollover frames?
          heathrowe Most Valuable Participant
          In the Export dialog, click the Options command.
          Click Document Specific and confirm what naming conventions is used for the Slice File Names AND Frames Names sections.
          h
          • 2. Re: Exporting images withOUT rollover frames?
            Level 7
            And what am I supposed to check for?
            -Darrel
            • 3. Re: Exporting images withOUT rollover frames?
              You have control how the filenames is outputted.
              Check what's in the Slice Names/Frames Names sections or change the allotted parameters to your liking.
              h
              • 4. Re: Exporting images withOUT rollover frames?
                Level 7
                That's not the issue. The issue is that slices that AREN'T set to a rollover
                behavior are still outputting two frames. Is there a way to stop that?
                For instance, I have three slices:
                a
                b
                c
                I set a and b to have simple rollover behaviors. I then export and get this:
                a
                a_f2
                b
                b_f2
                c
                c_f2
                I have no need/want for that c_f2 file.
                -Darrel
                • 5. Re: Exporting images withOUT rollover frames?
                  Level 7
                  One option is to use button symbols for those two-frame rollovers. They
                  will export properly and your single frame elements will exported
                  properly too.
                  Other options include selecting the two-frame slices and choose export
                  selected slices.
                  A third option if you have CS3 is to use multiple pages, and have those
                  two frame slices on their own page, and the rest of the document that
                  does not require two frames can reside on its own page.
                  If you're interested, I have a much more detailed article on this at
                  Community MX: http://www.communitymx.com/content/article.cfm?cid=9256F
                  HTH
                  Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
                  Extending Knowledge, Daily
                  http://www.communityMX.com/
                  CommunityMX - Free Resources:
                  http://www.communitymx.com/free.cfm
                  .:Adobe Community Expert for Fireworks:.
                  news://forums.macromedia.com/macromedia.fireworks
                  news://forums.macromedia.com/macromedia.dreamweaver
                  > a
                  > b
                  > c
                  > a
                  > a_f2
                  > b
                  > b_f2
                  > c
                  > c_f2
                  > -Darrel
                  • 6. Re: Exporting images withOUT rollover frames?
                    Thanks Jim for the workarounds
                    h
                    • 7. Re: Exporting images withOUT rollover frames?
                      Level 7
                      Thanks, Jim. I find this a silly 'bug', but I suppose the best workaround is
                      to just keep my rollover menus in a separate file.
                      _Darrel
                      Win prizes searching google:
                      http://www.blingo.com/friends?ref=hM72-GU3FWzMFnTqhv-2GE1FNtA
                      "Jim Babbage .:CMX:. & .:Adobe Community Expert:."
                      <jbabbage@newmediaservices.ca> wrote in message
                      news:fdts9j$srb$1@forums.macromedia.com...
                      > will export properly and your single frame elements will exported properly
                      > too.
                      > selected slices.
                      > two frame slices on their own page, and the rest of the document that does
                      > HTH
                      >> rollover behavior are still outputting two frames. Is there a way to stop
                      >> that?
                      >> a
                      >> b
                      >> c
                      >> this:
                      >> a
                      >> a_f2
                      >> b
                      >> b_f2
                      >> c
                      >> c_f2
                      >> -Darrel
                      • 8. Re: Exporting images withOUT rollover frames?
                        Level 7
                        > h
                        You're both welcome. Make sure to fill out your concerns on the Adobe
                        Wish list so they are brought to the attention of the developers.
