0 Replies Latest reply on Feb 8, 2010 5:42 PM by Jason Szeto
    [svn:fx-4.x] 14051: PopUpAnchor bug fix for Marshall Plan
    Jason Szeto Level 3
      Revision: 14051
      Revision: 14051
      Author:   jszeto@adobe.com
      Date:     2010-02-08 17:42:08 -0800 (Mon, 08 Feb 2010)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-25348 - Marshall Plan rendering error in AIR
      The fix is to replace PopUpAnchor.getPopUpMatrix() with MatrixUtil.getConcatenatedComputedMatrix(this).
      The PopUpAnchor needs to place the popUp relative to the SystemManager that is attaching the popUp. MatrixUtil.getConcatenatedComputedMatrix will stop at the correct displayList parent regardless if it is a trusted or untrusted sub app.
      QE notes: Add test case to mustella for this bug
      Doc notes: none
      Bugs: SDK-25348
      Reviewer: Alex
      Tests run: PopUpAnchor, DropDownList, ComboBox
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
