4 Replies Latest reply on Feb 16, 2010 6:51 AM by poloop
    How to set fontFamily with an embedded font of a textFlow ?
    poloop
      Hy,
      When I create a TextFlow without use any component of the flex SDK (4.0.13827) and then I try to change or apply a FontFamily of an embedded font, it doesn't work. Whereas when I use a component like RichEditableText or Label, it works.
      Bellow the code I wrote for my test :
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                  xmlns:mx="library://ns.adobe.com/flex/mx"
                                  creationComplete="creationCompleteHandler(event)"
                                  width="800" height="600"
           <fx:Style>
                @namespace s "library://ns.adobe.com/flex/spark";
                @namespace mx "library://ns.adobe.com/flex/mx";
                @namespace local "*";
                @font-face {
                     src:                         url("assets/Fonts/arial.ttf");
                     fontFamily:                  ArialEmbedded;
                     advandedAntiAliasing:      true;
                     cff:                              true;
                     unicodeRange:                U+0020-U+002F,U+0030-U+0039,U+003A-U+0040,U+0041-U+005A,U+005B-U+0060,U+0061-U+007A,U+007B-U+007E,U+00A1-U+00FF,U+2000-U+206F,U+20A0-U+20CF,U+2100-U+2183;
                @font-face {
                     src:                         url("assets/Fonts/cour.ttf");
                     fontFamily:                  CourierEmbedded;
                     cff:                              true;
                s|WindowedApplication
           </fx:Style>
           <fx:Script>
                <![CDATA[
                     import flash.text.Font;
                     import flash.text.engine.FontLookup;
                     import flashx.textLayout.container.ContainerController;
                     import flashx.textLayout.conversion.TextConverter;
                     import flashx.textLayout.edit.EditManager;
                     import flashx.textLayout.edit.IEditManager;
                     import flashx.textLayout.elements.TextFlow;
                     import flashx.textLayout.events.SelectionEvent;
                     import flashx.textLayout.formats.TextLayoutFormat;
                     import flashx.undo.UndoManager;
                     import mx.collections.ArrayCollection;
                     import mx.events.FlexEvent;
                     import spark.core.SpriteVisualElement;
                     import spark.events.IndexChangeEvent;
                     private var dynTextFlow : TextFlow;
                     private var ctTextFlow : TextFlow;
                     protected function creationCompleteHandler(event:FlexEvent):void
                          controlBarVisible=false;
                          dynTextFlow = TextConverter.importToFlow("Hello World", TextConverter.PLAIN_TEXT_FORMAT);
                          drawTextBloc(dynTextFlow);
                          dynTextFlow.addEventListener(SelectionEvent.SELECTION_CHANGE, selectionChangeListener);
                          dynTextFlow.fontFamily = "ArialEmbedded";
                          dynTextFlow.fontLookup = FontLookup.EMBEDDED_CFF;
                          dynTextFlow.fontSize = 24;
                          dynTextFlow.interactionManager = new EditManager(new UndoManager());
                          dynTextFlow.flowComposer.updateAllControllers();
                          dynTextFlow.invalidateAllFormats();
                     protected function cbFont_creationCompleteHandler(event:FlexEvent):void
                          var fonts:ArrayCollection=new ArrayCollection(Font.enumerateFonts());
                          cbFont.dataProvider=fonts;
                     protected function cbFont_changeHandler(event:IndexChangeEvent):void
                          var cf : TextLayoutFormat = new TextLayoutFormat();
                          cf.fontLookup = FontLookup.EMBEDDED_CFF;
                          cf.fontFamily = ComboBox(event.currentTarget).selectedItem.fontName;
                          IEditManager(ctTextFlow.interactionManager).applyLeafFormat(cf);
                          ctTextFlow.interactionManager.setFocus();
                     private function drawTextBloc(txt : TextFlow) : void
                          var container : SpriteVisualElement = new SpriteVisualElement();
                          var controller : ContainerController = new ContainerController(container, 300, 200);
                          addElement(container);
                          txt.fontLookup = FontLookup.EMBEDDED_CFF;
                          txt.fontFamily = "ArialEmbedded";
                          txt.flowComposer.addController(controller);
                     private function selectionChangeListener(event : SelectionEvent) : void
                          ctTextFlow = event.currentTarget as TextFlow;
                     protected function txt_selectionChangeHandler(event:FlexEvent):void
                          ctTextFlow = (event.currentTarget as RichEditableText).textFlow;
           </fx:Script>
           <fx:Declarations>
                <!-- Place non-visual elements (e.g., services, value objects) here -->
           </fx:Declarations>
           <s:layout>
                <s:VerticalLayout paddingLeft="10" paddingTop="10"/>
           </s:layout>
           <s:RichEditableText x="10"
                                    y="10"
                                    selectionChange="txt_selectionChangeHandler(event)"
                                    paddingTop="5" paddingLeft="5" paddingRight="5" paddingBottom="5"
                                    id="txt"
                                    fontFamily="CourierEmbedded"
                                    text="RichEditableText"
                                    height="200"
                                    width="350"/>
           <s:ComboBox id="cbFont"
                          labelField="fontName"
                          creationComplete="cbFont_creationCompleteHandler(event)"
                          change="cbFont_changeHandler(event)"
           <s:Label text="TEST" fontFamily="CourierEmbedded" fontSize="22" rotation="45"/>
      </s:WindowedApplication>
      Please, help me...
      Thank you very much...
