When I import a photo from the TOC / Info button/ Photo ... button/ zoom to 200 % feature does not seem to enlarge the image. The image as a result is far too small, which when published is above the TOC information on the left.
Can you help?
Hi there
I think you will have the best results by simply adjusting the image size prior to using it in the TOC. The optimum size is 60px X 60px. So use an image editing application to create the image you desire at that specific size and use that.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
I've resized the image to no avail. Acutally the image is much larger than the suggested 60 px x 60 px.
Is there a way to create a widget or a Flash element to make this logo appear larger in the upper left of the TOC? I can do some limited things in Flash 8.
can you add screenshots and version details (OS and Captivate)?
Captivate 9, 54 bit
First picture is what the output looks like and we need this image much large
Second picture is where we inserted the image
Thanks Eric, really appreciate it
I have the same question. We need our company logo to display larger at the top of the TOC and can't find out how to do this in Captivate 8. Any help would be appreciated!
I think this is the biggest it can be.
In the support file it does not say what is the maximum size Create a table of contents (TOC) with Adobe Captivate
Captivate doesn't currently offer any flexibility in this area. The image at the top of the TOC only ends up being very small and there are no configuration options whatsoever.
I suggest you log an enhancement request with Adobe about this. Articulate Storyline's player allows for much better presentation of company logos and branding. The Skin and TOC haven't really been improved significantly for many versions now. Captivate needs to lift its game in this particular area. Hopefully if more developers ask for enhancements, the Captivate team will respond.
HI,
I agree, there are needs of enhancements in several areas like the skin. I tried to use tutorials on making my own using Adobe Flash without great results.
