3 Replies Latest reply on Oct 2, 2007 3:08 PM by SriScape
    HTTPService response body for 5xx status codes
    sr
      I have an application that uses the HTTPService. I use the GET method and am sending XML. I am using this invoke a webservice without needing to use FDS. It works beautifully. However, if the service I am calling encounters an error, it sets the status code to 5xx and sends back an XML results in the response body. I do not see a way of getting that within my fault handler. I have found discussions on other sites that say that you do not have access to the response body unless the status code is in the 2xx series. Is this true? Is there really no way to access the response body?
