3 Replies Latest reply on Feb 9, 2010 10:21 AM by cyber0897
    this.textDisplay does not seem to work...  is there a work around for this??
    cyber0897 Level 1
      hey guys... so im trying to create a text box which would have a prompt, and on focus of that textbox it would clear out that prompt from in the text box...
      the problem is i have no idea why its not working... it seems to be displaying the prompt... but my onfocus event is never called...
      it seems as if i never get into the if statement that says
      if(instance == this.textDisplay)
      the textDisplay used to be textView... but after tons of research i found out that textView has been changed to textDisplay...
      any help why i cant getinto that if statement would be GREATLY appretiated!!! ive spent over a day on this stupid issue... lol
      thanks a ton for all you help
      the code i have is...
      main app:
      <textbox:advancedTextInput id="fileName" prompt="File Name"
           skinClass="components.textbox.advancedTextInputSkin" />
      in the advancedTextInput.as file...
      package components.textbox
           import flash.events.FocusEvent;
           import spark.components.TextInput;
           public class advancedTextInput extends TextInput
                public function advancedTextInput()
                     super();
                [SkinPart(required="true")]
                public var promptView:TextInput;
                [SkinState("focused")];
                private var _prompt:String
                private var promptChanged:Boolean;
                [Bindable]
                public function get prompt():String
                     return _prompt;
                public function set prompt(v:String):void
                     _prompt = v;
                     promptChanged = true;
                     invalidateProperties();
                override public function set text(val:String):void
                     super.text = val;
                     if (promptView && text == "")
                          promptView.visible = true;
                override protected function commitProperties():void
                     super.commitProperties();
                     if (promptChanged)
                          if (promptView)
                               promptView.text = prompt;
                          promptChanged = false;
                override protected function partAdded(partName:String, instance:Object):void
                     super.partAdded(partName, instance);
        ------------------>     if (instance == this.textDisplay)
                          this.textDisplay.addEventListener(FocusEvent.FOCUS_IN, onFocusInHandler);
                          this.textDisplay.addEventListener(FocusEvent.FOCUS_OUT, onFocusOutHandler);
                     if (instance == promptView)
                override protected function partRemoved(partName:String, instance:Object):void
                     super.partRemoved(partName, instance);
                          this.textDisplay.removeEventListener(FocusEvent.FOCUS_IN, onFocusInHandler);
                          this.textDisplay.removeEventListener(FocusEvent.FOCUS_OUT, onFocusOutHandler);
                private function onFocusInHandler(event:FocusEvent):void
                     if (promptView)
                          promptView.visible = false;
                private function onFocusOutHandler(event:FocusEvent):void
                     if (promptView)
                          if (text == "")
                          else
      and the skin contains....
      <s:sparkSkin>
           <s:RichEditableText
                id="viewText"
                bottom="1"
                left="1"
                paddingBottom="3"
                paddingLeft="3"
                paddingRight="3"
                paddingTop="5"
                right="1"
                top="1"
                lineBreak="explicit"
           <!-- prompt -->
           <s:TextInput
                id="promptView"
                bottom="1"
                color="#999999"
                fontStyle="italic"
                left="1"
                paddingBottom="3"
                paddingLeft="3"
                paddingRight="3"
                paddingTop="5"
                right="1"
                top="1"
      </s:SparkSkin>
        • 1. Re: this.textDisplay does not seem to work...  is there a work around for this??
          Flex harUI Adobe Employee
          There is no component with id="textDisplay" in your skin
          • 2. Re: this.textDisplay does not seem to work...  is there a work around for this??
            cyber0897 Level 1
            oh oops.. i actually changed that... my skin ended up being
                <s:RichEditableText
                    id="textDisplay"
                    bottom="1"
                    left="1"
                    paddingBottom="3"
                    paddingLeft="3"
                    paddingRight="3"
                    paddingTop="5"
                    right="1"
                    top="1"
            but it still does not work...
            • 3. Re: this.textDisplay does not seem to work...  is there a work around for this??
              cyber0897 Level 1
              actually... since my code was not working at all.. i just decided to changed the entire thing... and i ended up with
                   import mx.controls.TextInput;
                        private var _defaultText:String;
                             super();
                             if( text == ""){
                                  text = defaultText;
                                  setStyle("color", "0x808080")
                                  setStyle("fontStyle","italic");
                             addEventListener(FocusEvent.FOCUS_IN, FocusIn);
                             addEventListener(FocusEvent.FOCUS_OUT, focusOut);
                        public function set defaultText(value:String):void{
                             _defaultText = value;
                             if( text == ""){
                                  text = defaultText;
                             }else{
                                  setStyle("color", "0x0B333C")
                                  setStyle("fontStyle","none");
                        public function get defaultText():String{
                             return _defaultText;
                        private function FocusIn(event:FocusEvent):void{
                             if( text == defaultText ){
                                  text = "";
                        private function focusOut(event:FocusEvent):void{
                             if( text == "" ){
                                  text = defaultText;
                             }else{
              this code works like a camp... thanks a ton for you help tho...!
