4 Replies Latest reply on Mar 12, 2010 7:12 AM by Harry Kunz
    Is it possible to open a Outlook vCard from Flash?
    hawksquest
      I have a button that when clicked "should" open a vCard from Outlook 2007. Is this possible using AS2 and if so, what would the code be?
      Thanks.
        • 1. Re: Is it possible to open a Outlook vCard from Flash?
          Harry Kunz Level 4
          I don't think ActionScript supports any APIs that can do that.
          • 2. Re: Is it possible to open a Outlook vCard from Flash?
            Harry Kunz Level 4
            Hi, i just realized that vCards are just ordinary text files with an extension of ".vcf" that contain plain text content similar as the following text:
            BEGIN:VCARD
            VERSION:2.1
            SOURCE:Yahoo! AddressBook (http://address.yahoo.com)
            PRODID:-//Yahoo!/AddressBook/YAB3/2010
            FN;CHARSET=utf-8:Harry Roland Kunz
            N;CHARSET=utf-8:Kunz;Harry Roland;;;
            EMAIL;INTERNET;PREF;CHARSET=utf-8:harryrolandkunz@yahoo.com
            UID;CHARSET=utf-8:556ded4603cf1ef789bead6c3c5f114f
            X-CID;CHARSET=utf-8:16777388
            X-CREATED;CHARSET=utf-8:1266555402
            X-MODIFIED;CHARSET=utf-8:1266555413
            REV;CHARSET=utf-8:292
            X-PRIMARY-PHONE;CHARSET=utf-8:0
            END:VCARD
            BEGIN:VCARD
            VERSION:2.1
            FN;CHARSET=utf-8:Harry Kunz
            N;CHARSET=utf-8:Kunz;Harry;;;
            EMAIL;INTERNET;PREF;CHARSET=utf-8:Name@somedomain.com
            UID;CHARSET=utf-8:38a6e0c55aaa550e914b3f59377abd16
            X-CID;CHARSET=utf-8:16777391
            X-CREATED;CHARSET=utf-8:1266593012
            X-MODIFIED;CHARSET=utf-8:1266593021
            REV;CHARSET=utf-8:297
            END:VCARD
            This is an example of 2 contact information. You can load it using the native XML class (but that may not be the best way) with a code like:
            var cXml:Object = new XML();
            cXml.onLoad = function(fSuccess:Boolean)
               trace(fSuccess);
               trace(cXml);
            cXml.load("vCard.vcf");
            And then do a string search for "BEGIN" and count how many matches of contacts are in the file (in case it is more than one). But i would suggest you better convert the vCard content to an XML standardized file so that it's easier to parse with the standard methods available today. You could do that by for example:
            <?xml version="1.0" encoding="UTF-8"?>
            <vcard>
               <contact id="1">
                  <lastname>John</lastname>
                  <firstname>TheBaptist</firstname>
                  <email>john@baptist.com</email>
               </contact>
               <contact id="2">
                  <lastname>Craig</lastname>
                  <firstname>David</firstname>
                  <email>craig@baptist.com</email>
               </contact>
            </vcard>
            • 3. Re: Is it possible to open a Outlook vCard from Flash?
              hawksquest Level 1
              Excellent!!! Thank you so very much. I shall be excited to try it out.
