2 Replies Latest reply on Feb 10, 2010 9:21 AM by iamiqbal
    Flex and Java Web service
    iamiqbal
      Hello:
      I am trying to integrate java web service with Flex UI.
      The output from webservice is collection of java objects. I want that to be displayed in grid.
      I am not able to display the output obtained from my webs service call into grid. I can display if the output is just a simple string but not collection
      of data objects.
      Appreciate if anyone can help me on this.
      I have developed following artifacts.
      My java webservice is as below:
      * To change this template, choose Tools | Templates
      * and open the template in the editor.
      package com.mst.soa;
      import java.util.ArrayList;
      import java.util.List;
      import javax.jws.WebMethod;
      import javax.jws.WebService;
      * @author iamiqbal
      @WebService()
      public class LoggerWS {
          @WebMethod
          public String getLogger(String interfaceName,String fromDate){
              System.out.println("Web service Logger WS invoked");
              return "Batch Started and Completed Successfully";
           public List<Employee> getList(String interfaceName,String fromDate){
              System.out.println("Web service getList method invoked");
              List tempList = new ArrayList();
              Employee emp = new Employee();
              emp.setName("name1");
              tempList.add(emp);
              Employee emp1 = new Employee();
              emp1.setName("name2");
              tempList.add(emp1);
              //tempList.add("name2");
              return tempList;
      My felx application is as below:
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml"
      layout="
      vertical"
      verticalAlign="
      middle"
      backgroundColor="
      white" viewSourceURL="srcview/index.html">
      <mx:Script>
      <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.events.FaultEvent;
      import mx.utils.ObjectUtil;
      private var startTime:int;
      private var endTime:int;
      Bindable]
      private var dataVar:ArrayCollection;
      private function button_click():void {
      webServiceGetList.getList.send();
      //webService.getLogger.send();
      startTime = getTimer();
      lbl.text =
      "Wait.......";
      private function display(evt:ResultEvent):void {
      textField.text = ObjectUtil.toString(evt.result);
      //textField.text += ObjectUtil.toString(evt.result.surname);
      calcTime();
      private function displayList(evt:ResultEvent):void {
      //dataVar = (ArrayCollection)evt.result;
      //dataVar = evt.result;
      //ArrayCollection arrayCollection = new ArrayCollection();
      //textField.text = (evt.result);
      calcTime();
      private function displayfault(evt:FaultEvent):void {
      Alert.show(evt.type);
      calcTime();
      lbl.text =
      "ERROR:::::";
      private function calcTime():void {
      endTime = getTimer();
      lbl.text =
      "total time: " + (endTime - startTime) + "ms";
      </mx:Script>
      <mx:WebService id="webService"
      wsdl="
      http://localhost:8080/MSTDealWebServices/LoggerWSService?wsdl"
      useProxy="
      false">
      <mx:operation name="getLogger"
      resultFormat="
      object"
      result="display(event);"
      fault="displayfault(event);"
      <mx:request xmlns="" >
      <arg0>Iqbal</arg0>
      <arg1>Mohiuddin</arg1>
      </mx:request>
      </mx:operation>
      </mx:WebService>
      <mx:WebService id="webServiceGetList"
      wsdl="
      useProxy="
      false">
      <mx:operation name="getList"
      resultFormat="
      object"
      result="displayList(event);"
      <arg0>Iqbal</arg0>
      </mx:request>
      </mx:operation>
      </mx:WebService>
      <mx:Label text="Web Service output"/>
      <mx:TextInput id="textField"
      editable="
      false" />
      <mx:DataGrid id="data" dataProvider="{dataVar}"/>
      <mx:Spacer width="100%" />
      <mx:ApplicationControlBar dock="true">
      <mx:Button id="button"
      label="
      call web service"
      click="button_click();"
      <mx:Label id="lbl" />
      </mx:ApplicationControlBar>
      </mx:Application>
      package
      test
      Bindable]
      public class Employee
      private var name:String;
      public function Employee()
