3 Replies Latest reply: Feb 10, 2010 9:22 AM by jdmack01 RSS
    Encoding video for iphone?
    avpromedia Community Member
      Starting from having a 4:3 video clip in premiere, what is the best way to encode it for my iphone / ipod touch?
      Quality is top priority.
      Not looking for a tutorial; just need a few sentences describing the settings.
      E.g. should I de-interlace? what video format to encode to?
      I have premiere pro cs4 on winXP.
        • 1. Re: Encoding video for iphone?
          pmasters8941 Community Member
          AME already has encoding presets under the H.264 drop downs.
          • 2. Re: Encoding video for iphone?
            dradeke Adobe Employee
            Yes, just select H.264 and then probably the iPod Video Large preset.
            Dennis
            • 3. Re: Encoding video for iphone?
              jdmack01 Community Member
              I had some trouble with the iPhone presets in Premiere.  Here's an alternate solution if that doesn't work for you.
              Export your project as a NTSC DV Quicktime file (I suspect PAL DV would work as well if that's the format one is working with)
              Open iTunes
              Add this Quicktime file to your Movies library in iTunes
              Right click on the icon for your Quicktime file in iTunes, and choose "Create iPod or iPhone version"
              iTunes will convert the file for you, and save it to whatever subdirectory that is set in your preferences.
              There does not seem to be any settings tweaks prior to the conversion.
              J. D.
