0 Replies Latest reply on Sep 30, 2007 4:42 PM by handsomek
    loading jpegs into video playlist from XML
    handsomek
      I would be gratefull if anyone out there might be able to help me.
      I want to display jpegs alongside the text when selecting which videos to play,
      the problem is I am not sure how to change the xml file and the actionscript.
      Can you please help.
      Here is the code
      var connection_nc:NetConnection = new NetConnection();
      connection_nc.connect(null);
      var stream_ns:NetStream = new NetStream(connection_nc);
      stream_ns.setBufferTime (30);
      stream_ns.onStatus = function (info) {
      if(info.code == "NetStream.Buffer.Full") {
      bufferClip._visible = false;
      if(info.code == "NetStream.Buffer.Empty") {
      bufferClip._visible = true;
      video.attachVideo(stream_ns);
      rewindButton.onRelease = function() {
      stream_ns.seek(0);
      playButton.onRelease = function() {
      stream_ns.pause();
      var vlist:XML = new XML ();
      vlist.ignoreWhite = true;
      vlist.onLoad = function (){
      var videos:Array = this.firstChild.childNodes;
      for (i=0;i<videos.length;i++) {
      videoList.addItem(videos .attributes.thumb,videos.attributes.url);
      stream_ns.play(videoList.getItemAt (0) .data) ;
      videoList.selectedIndex = 0;
      var vidList:Object = new Object();
      vidList.change = function() {
      stream_ns.play (videoList.getItemAt(videoList.selectedIndex).data );
      videoList.addEventListener("change",vidList);
      vlist.load("video.xml");
      var videoInterval = setInterval(videoStatus,100);
      var amountLoaded:Number;
      var duration:Number;
      stream_ns["onMetaData"] = function(obj) {
      duration = obj.duration;
      function videoStatus() {
      amountLoaded = stream_ns.bytesLoaded / stream_ns.bytesTotal;
      loader.loadbar._width = amountLoaded * 297.9;
      loader.scrub._x = stream_ns.time / duration * 297.9;
      var scrubInterval;
      loader.scrub.onPress = function() {
      clearInterval(videoInterval);
      scrubInterval = setInterval(scrubit,10);
      this.startDrag(false,0,this._y,289,this._y);
      loader.scrub.onRelease = loader.scrub.onReleaseOutside = function() {
      clearInterval(scrubInterval);
      this.stopDrag();
      function scrubit() {
      stream_ns.seek(Math.floor((loader.scrub._x/289) * duration));
      _root.createEmptyMovieClip("vSound",_root.getNextH ighestDepth());
      vSound.attachAudio(stream_ns);
      var so:Sound = new Sound(vSound);
      so.setVolume(100);
      mute.onRollOver = function() {
      if (so.getVolume() == 100) {
      this.gotoAndStop("onOver");
      else {
      this.gotoAndStop("muteOver");
      mute.onRollOut = function() {
      this.gotoAndStop("on");
      else {
      this.gotoAndStop("mute");
      mute.onRelease = function() {
      so.setVolume(0);
      else {
      so.setVolume(100);
      Here is the XML
      <?xml version="1.0" encoding="ISO-8859-1"?>
      <videos>
      <video url=" http://fimm.tv/09072007.flv" desc="Come & Drink - Linda Faith" thumb="test.jpg" />
      </videos>
      </xml>
