0 Replies Latest reply on Feb 9, 2010 4:16 PM by jackrabbit223344
    Instantiating, Positioning and animating Sprites
    jackrabbit223344
      Hello,
      The application in question is here:
      mhayden.jahnews.com/workSample/BrickBuilder/ClassBasedSprite.html
      You can right click and see the source.
      My questions are as follows:
      1.) How can I instantiate the bricks without taking such a big performance hit?
           a.) currently, I’m instantiate the bricks that make a column one at a time. I tried doing this with a repeater which did work but I could not get the animation to work on each individual brick. The animation would only work across the entire column.
      2.) How can I get the UIComponent that contains the brick columns to align itself to the vertical bottom 10 pixels above the box along the bottom with the slider?
           a.) I'm currently adding a UIComponent to the stage dynamically and then keeping a reference to that UIComponenet, I am adding my bricks.
      3.) How can I improve the animation?
           a.) Most of my research has suggested the only way to animate a sprite is to use a Timer() or connect to the onEnterFrame event.
      Any critique, help or comments would be greatly appreciated.
