2 Replies Latest reply on Feb 9, 2010 11:32 PM by ramell2
    Tile List limits
    ramell2
      I have a TileList with drag feature on.  I can drag images into another TileList I have on the page.  I want to set a limit on the number of images that the user can drag to the second TileList.  Should i write a actionscript function that once the number limit is reach it stops the drag function?  Or is there a method in the TileList class  I can use?
        • 1. Re: Tile List limits
          archemedia Level 4
          First of all, add an event listener to your second (drop) list for the dragDrop event:
          <mx:TileList dataProvider="{dp1}" dragEnabled="true"/>
          <mx:TileList dataProvider="{dp2}" dropEnabled="true" dragDrop="checkDrop(event)"/>
          Then, in the checkDrop function, call the preventDefault function to stop the drop completing:
          private function checkDrop(evt:DragEvent):void
                    if (dp2.length >= 3)
                        evt.preventDefault();
          Hope this helps
          Dany
          • 2. Re: Tile List limits
            ramell2 Level 1
            Thank you so much archemedia. This was what I thought I needed to do..
