0 Replies Latest reply on Feb 9, 2010 4:57 PM by GordonSmith
    [svn:fx-trunk] 14079: Set svn:eol-style to "native" and svn:mime-type to " text/plain" for non-auto-generated .java files in trunk.
    GordonSmith Level 4
      Revision: 14079
      Revision: 14079
      Author:   gosmith@adobe.com
      Date:     2010-02-09 16:57:36 -0800 (Tue, 09 Feb 2010)
      Log Message:
      Set svn:eol-style to "native" and svn:mime-type to "text/plain" for non-auto-generated .java files in trunk.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: None
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/modules/antTasks/src/flex/ant/AsDocTask.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/AbcThunkGen.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Algorithms.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Binding.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Block.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/CallGraph.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Edge.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Expr.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Handler.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Method.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Name.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Namespace.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Nsset.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/OptimizerConstants.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/OptimizerPlugin.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Symtab.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/TraceManager.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Type.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/TypeAnalysis.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/TypeCache.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Typeref.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/LiteralVectorNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NumericConversions.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsClass.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocHelper.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/QualifiedNameInfo.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/SortComparator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClassesGenerator.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionManager.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MxmlCommentUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcChecksums.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/FilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/FillMode.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/CompressionLevel.java
      Property Changed:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SkinPartEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SkinPartExtension.java
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/AlreadyActiveApplicationExc eption.java
          flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/ILaunchNotification.java
