0 Replies Latest reply on Feb 9, 2010 10:20 PM by GordonSmith
    [svn:fx-trunk] 14081: Added opensource copyright notices for . java files in trunk that didn't have them.
    GordonSmith Level 4
      Revision: 14081
      Revision: 14081
      Author:   gosmith@adobe.com
      Date:     2010-02-09 22:20:25 -0800 (Tue, 09 Feb 2010)
      Log Message:
      Added opensource copyright notices for .java files in trunk that didn't have them.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: None
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Algorithms.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Binding.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Block.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/CallGraph.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Edge.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Expr.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Handler.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Method.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Name.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Namespace.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Nsset.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/OptimizerConstants.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/OptimizerPlugin.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Symtab.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/TraceManager.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Type.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/TypeAnalysis.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/TypeCache.java
          flex/sdk/trunk/modules/asc/src/java/adobe/abc/Typeref.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/LiteralVectorNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/TypeIdentifierNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UseNumericNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UsePragmaNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UsePrecisionNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/UseRoundingNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ParameterizedName.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Decimal128.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Decimal128Context.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/DecimalNumberConstant.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/DenselyPackedDecimal.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/DoubleNumberConstant.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/IntNumberConstant.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NumberConstant.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NumberUsage.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NumericConversions.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/UintNumberConstant.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionManager.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ExtensionsConfiguratio n.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IApplicationExtension. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ICompcExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IConfigurableExtension .java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/ILibraryExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IMxmlcExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IPreCompileExtension.j ava
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/IPreLinkExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/extensions/util/ListMap.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/DeclarationsNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/ReparentNode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/StatesGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/DynamicProperty.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/ElementTypeNotFound. java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/PerformanceData.java
          flex/sdk/trunk/modules/compiler/test/java/flash/localization/LocalizationTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/common/ConfigurationTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/common/FontsConfigurationTest.ja va
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ComplexTypeTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ConfigInfoDependencyTest. java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ConfigInfoListTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ConfigInfoNamedMultipleTe st.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ConfigInfoNamedTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ContextTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/DefaultsTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/ExceptionTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/MergeBuffersTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/SimpleChildConfigTest.jav a
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/SimpleStringTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/SimpleTypesArrayTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/SimpleTypesListTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/SimpleTypesTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/UberConfigTest.java
          flex/sdk/trunk/modules/compiler/test/java/flex2/compiler/config/UsageTest.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/DropShadowFil terNode.java
          flex/sdk/trunk/modules/webtier/j2ee/coldfusion/src/java/coldfusion/bootstrap/BootstrapBod yTag.java
          flex/sdk/trunk/modules/webtier/j2ee/coldfusion/src/java/coldfusion/bootstrap/BootstrapTag .java
          flex/sdk/trunk/modules/webtier/j2ee/coldfusion/src/java/coldfusion/bootstrap/TagGenerator .java
