1 Reply Latest reply on Feb 12, 2010 5:54 PM by smackmick
    Split Code and Design will not stay
    smackmick
      I like the classic design with the split screen code on top and design on the bottom.  Somehow I have gotten it where it will also come up in code, the splot and design are greyed out.  I can force it to split with the layout, and I save this as a template.  But whenever I bring up a new page, I either have to reset the template or hit layout to force the split.  Very annoying.
      I have looked all over and I cannot see a setting.  Live view/Live code are off, in fact greyed out.  I just tried to reload the software completely and this did not reset it.
        • 1. Re: Split Code and Design will not stay
          smackmick Level 1
          I opened a case to Support, and they fixed it.  I needed to delete the Configuration file and then edit the regedit, removing the CS4 entry.  I did not have much in the way of customization,so it was not a big deal.
          My thanks to the Suport Team.
          Re-create the Dreamweaver preferences folder to eliminate problems that
          a damaged preferences files might cause.
          Note: When you use this solution, Dreamweaver will create a new
          preferences folder and you will lose custom settings associated with
          your current preferences file. However, the folder you rename in step 2
          is your original preferences file. If you determine that the preferences
          files is not causing the problem, then you can restore your custom
          settings by following the instructions below.
          Disclaimer: This procedure involves editing the Windows registry. Adobe
          doesn't provide support for editing the registry, which contains
          critical system and application information. Make sure to back up the
          registry before editing it. For more information about the registry, see
          the Windows documentation or contact Microsoft.
          To re-create the Dreamweaver preferences file:
          1. Quit Dreamweaver.
          2. Rename the Configuration folder (for example, Configuration old)
          in the "\Users\[user]\AppData\Roaming\Adobe\Dreamweaver CS4\(
          installation language)\" folder.
          3. Choose Start > type regedit, then press Enter, and click Continue
          for the next dialog box. (note, this did not work in Win 7, had to get help to find new regedit).
          4. Browse to the following location:
          HKEY_CURRENT_USER\Software\Adobe\Dreamweaver CS4 and delete the whole
          Dreamweaver CS4 folder then close the registry editor.
          5. Start Dreamweaver. Dreamweaver creates a new preferences file.
          If the problem continues, then the preferences file isn't the cause. To
          restore custom settings, delete the new preferences file and restore the
          original name of the previous preferences file.
