• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Audio attached to PPT buttons lost after publish
New Here ,
Feb 09, 2010 Feb 09, 2010
I have a set of PPT slides which include some on-screen buttons that cause a sound to be played when they are clicked.  (I attached the sound via Right-click -> Action Settings -> Play Sound.)  After I publish the presentation and run it, the buttons no longer play the sounds.
How can I have a sound played when I click a button in a published presentation?
Thanks...
TOPICS
Presenter
Views
342
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
Feb 10, 2010 Feb 10, 2010
LATEST
RW,
I know that this is not the answer you want to hear, but using Action Settings PPT and then publishing to Presenter just won't work.  If not mistaken, I believe you're attempting to use VB Script controls that Presenter isn't equipped to deal with.  The same goes for Action Buttons in PowerPoint.  Those will fail every time.
However, there are a couple of workarounds you could use...but that will depend on what you're trying to create.
Method 1: use a flash .swf file to accomplish the job.  This obviously requires that you'd need to "program" some functionality in Flash to pull it off, but it can be done.  Quick heads-up here: do NOT code using Actionscript 3.0 if this is a path you're going to take.
Method 2: another way to "fake" it is to use a hidden slide w/ your audio clip incorporated using the Import command from Presenter. Basic gist looks like this: you have your "main" slide w/ a button, graphic, etc on it....and if you right-click, you can choose "hyperlink"...which then can be used to connect your main slide to the hidden slide (which might contain your audio for example).
Again, not the most ideal situation, but trying to use Action Settings is going to prove more frustrating than it's worth.
Just my 2 cents....
Rob
http://www.robrode.com/yabb
Votes
Translate
Translate
Report
Report
Resources
Help resources
