3 Replies Latest reply on Feb 10, 2010 4:17 AM by Harry Kunz
    Referring to dynamically created movieclips
    bwanakahawa
         I'm having real trouble doing something probably very simple.
      I need to dynamically create a group of movieclips which will eventually be options on a menu. The number of projects is a variable, so I tried to create them through a FOR loop.
      Code:
      numProjects:Number = 3;
      for (var j:Number = 1; j <= numProjects; j++) {
           var button:MovieClip = createEmptyMovieClip("button"+j, j);
           button.beginFill(0xFF0000, 100);
           button.moveTo(5, 115+(j*20));
           button.lineTo(15, 115+(j*20));
           button.lineTo(15, 125+(j*20));
           button.lineTo(5, 125+(j*20));
           button.endFill();
           trace("button "+j+" created");
           button.onRelease = function() {
                trace("j = "+j);
      The problem is, I get 'j = 4' as the trace for all buttons, so something's obviously wrong...
      And how would I later refer to the buttons from another movieclip?
      Could I use this tov remove them all?
                _root.button["button"+j].removeClip();
      Sorry for the noob questions but I'm stumped here!
        • 1. Re: Referring to dynamically created movieclips
          Harry Kunz Level 4
          That is because "j" is "global" variable in reference to the function. And at the time you have pressed the button, the loop has already finished long time ago with a final "j" value of 4. Why are you tracing j anyway, as an id value? You may want to get the name of the movieclip or its depth by using:
                    trace("mc = " + this._name + " -> has depth of: " + this.getDepth());
          • 2. Re: Referring to dynamically created movieclips
            bwanakahawa Level 1
            Thanks for that.
            Firstly, how come j reaches 4? The for loop tells it to stop when it equals 3.
            Secondly, how would I later refer to the buttons using another loop (if I wanted to, say, move them or something)?
            Using:
                 _root."button"+j._x += 200;
            throws up the error "Left side of assignment operator must be variable or property"
            Cheers,
            Derek
            • 3. Re: Referring to dynamically created movieclips
              Harry Kunz Level 4
              Try this simple test
              for(var n = 1; n <= 3; n++)
                 trace(n);
              trace(n);
              The loop starts with 1. Each loop cycle ends with incrementing the n value then starts again by checking if it is less than or equal to 3. Then repeats the process until it reaches a value that will not satisfy the condition n <= 3 which is n = 4 and thus signals to exit the for loop. That is why the trace statement after the for loop is 4 which caused the loop to stop.
              You can use eval like this:
                 var mcButton:MovieClip = eval("_root.button" + j);
                 mcButton._x += 200;
