17 Replies Latest reply on Feb 16, 2010 12:32 AM by Scott R. Hamilton
    Using addChild() in an ActionScript vs. in a Class
    Scott R. Hamilton Level 1
      I have defined  ActionScript Class by adding all of the script code  from an AS script file
      (plus a standard constructor method).
      This was working as a Script but the Class file will not compile. I'm getting not defined
      errors for addChild() and removeChild().
        • 2. Re: Using addChild() in an ActionScript vs. in a Class
          Gregory Lafrance Level 6
          If you just "include" the .as script somewhere else in your code, if the container where the code was "included" supports the addChild() and removeChild() methods, you are all set, as you have seen.
          But if you are using this code in a class, the class must support the addChild() and removeChild() methods.
          Does your class extend at least UIComponent, or some other class that cupports the addChild() and removeChild() methods, such as VBox, etc.
          If you are extending no other class, then that's your problem, and simply extending UIComponent should fix the issue:
          import mx.core.UIComponent;
          public class MyClass extends UIComponent{
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          www.ChikaraDev.com
          Flex / AIR Development, Training, and Support Services
          • 3. Re: Using addChild() in an ActionScript vs. in a Class
            Here's tje cpde.
            The compiler if flagging these lines:
              addChild(formPrintView);
              removeChild(formPrintView);
              formPrintView.imPrtPict.source = fileReference.data;
            AddChild, RemoveChild and fileReference as not defined
            package
                public class PrintRecipeGlobal
                    public function PrintRecipeGlobal()
                    //                     _______
                    static public function doPrint(sTitle:String, sSubTitle:String, sCreator:String, sSource:String,
                                            sOrigin:String, sIntro:String, sPrepTime:String, sCookTime:String,
                                            sServings:String, sIngr:String, sPrep:String, sImagePath:String):void {
                    import mx.controls.Alert;
                    import mx.printing.FlexPrintJob;
                    import flash.display.*;
                    import flash.events.Event;
                    import flash.net.URLRequest;
                    import flash.display.Sprite;
                    import flash.display.Stage;
                    import flash.text.*;
                    import flash.events.*;
                        //Alert.show("Printing called");
                        // Create a FlexPrintJob instance.
                        var printJob:FlexPrintJob = new FlexPrintJob();
                        // Start the print job.
                        if(printJob.start()) {
                            // Create a MyPrintView control as a child
                            // of the current view.
                            var formPrintView:PrtViewCreateScr = new PrtViewCreateScr();
                            // Populate the print control's structures with the text from
                            //the create recipe screen
                            formPrintView.lblTitle.text = sTitle;
                            formPrintView.lblSubTitle.text = sSubTitle;
                            formPrintView.lblCreator.text = sCreator;
                            formPrintView.lblSource.text = sSource;
                            formPrintView.lblOrigin.text = sOrigin;
                            formPrintView.taPrtIntro.text = sIntro;
                            formPrintView.lblPrepTime.text = sPrepTime;
                            formPrintView.lblCookTime.text = sCookTime;
                            formPrintView.lblServings.text = sServings;
                            formPrintView.taPrtIngrList.text = sIngr;
                            formPrintView.taPrtPreparation.text = sPrep;
                            //Alert.show("Image Path: " + "file///" + sImagePath);
                            //formPrintView.imPrtPict.load(sImagePath);
                            if (sImagePath != "") {
                                var pictLdr:Loader = new Loader();
                                var pictURLReq:URLRequest = new URLRequest("file:///" + sImagePath);
                                pictLdr.load(pictURLReq);
                                pictLdr.contentLoaderInfo.addEventListener(Event.COMPLETE, imgLoaded);
                            // Add the SimplePrintview control to the print job.
                            // For comparison, try setting the
                            // second parameter to "none".
                            printJob.addObject(formPrintView);
                            // Send the job to the printer.
                            printJob.send();
                            // Remove the print-specific control to free memory.
                        function imgLoaded(event:Event):void
                                Alert.show("Image load complete");
                                //formPrintView.imPrtPict.source = sImagePath;
                    // function doPrint
                // class PrintRecipeGlobal
            • 4. Re: Using addChild() in an ActionScript vs. in a Class
              Like I said, try this:
              public class PrintRecipeGlobal extends UIComponent
              www.ChikaraDev.com
              • 5. Re: Using addChild() in an ActionScript vs. in a Class
                This is what I've done (thanks for the idea Greg):
                   [class code]
                The original errors are now gone (addChild(), removeChild() and FileReference not defined)
                What I'm now getting is:
                The definition of the base class UIComponent could not be found.
                How can this be? The errors being generated by not incorporating the base
                class UIComponent are gone but the base class itself cannot be found? So
                where  is the compiler getting the definitions for addChild(), removeChild() and
                FileReference?
                Very confusing!
                Scott
                • 6. Re: Using addChild() in an ActionScript vs. in a Class
                  So what do I have to do to get the flex compiler to recognize the UIComponent base class?
                  • 7. Re: Using addChild() in an ActionScript vs. in a Class
                    Jason Szeto Level 3
                    Scott,
                    You need to import mx.core.UIComponent.
                    A handy trick I use in FlashBuilder is to put your caret at the end of the class and type "Ctrl-SPACE". It will automatically insert the import statement for you.
                    Jason
                    • 8. Re: Using addChild() in an ActionScript vs. in a Class
                      Thanks for your tip Jason,
                      unfortunately, the problem just pops up again somewhere else.
                      If I put the import statment between the package and class definitions like so:
                      package
                      I get undefined messages on compile for addChild, removeChild and fileReference again.
                      If I move the import into the class definition like this:
                      package
                      I get "... base class definition for UIComponent not found".
                      I'm at my wits end here...there must be something of a very bassic nature that is
                      wrong.
                      Where can I find out exactly what imports I need in order to create a class in ActionScript?
                      Scott
                      • 9. Re: Using addChild() in an ActionScript vs. in a Class
                        This code works. How does your code differ (in relevant ways)?
                        package
                          import mx.controls.Button;
                          public class PrintRecipeGlobal extends UIComponent{
                            public function PrintRecipeGlobal(){
                              var btn:Button = new Button();
                              this.addChild(btn);
                        <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                          creationComplete="init()">
                          <mx:Script>
                            <![CDATA[
                              private function init():void{
                                var prg:PrintRecipeGlobal = new PrintRecipeGlobal();
                                this.addChild(prg);
                          </mx:Script>
                        </mx:Application>
                        www.ChikaraDev.com
                        • 10. Re: Using addChild() in an ActionScript vs. in a Class
                          Hi Greg,
                          I've spent some time reducing this down to a base minimum but I
                          still get the same error (base class component not found):
                          package
                              import mx.core.UIComponentDescriptor;
                                      super();
                                  //                           _______
                                          printJob.send();
                                  // function doPrint
                          • 11. Re: Using addChild() in an ActionScript vs. in a Class
                            Hi Greg,
                            I tried your example  -  the mxml and the class.
                            The result is that there are no compile errors, but the button
                            defined does not appear on the screen, which may or may not
                            be an issue.
                            I guess that what's important is that the class can be successfully
                            defined as an extension of UIComponent.
                            What I will try next is to isolate the class definition  and mxml
                            to see if this will work. I will define the two in a separate project
                            to see if collateral effects in my original project were playing
                            a role.
                            Regards,
                            Scott
                            • 12. Re: Using addChild() in an ActionScript vs. in a Class
                              In your latest posted code, you don't have a line import mx.core.UIComponent.
                              Flex Builder is strange sometimes in that it sometimes removed necessary import statements automatically (and erroneously)! If you get errors, always check your imports to ensure Flex Builder did not screw you.
                              Here is your latest posted code, amended and working (with code I don't have commented out):
                              package
                                          super();
                                      //                           _______
                                              printJob.send();
                              //                    formPrintView.imPrtPict.load(sImagePath);
                                      // function doPrint
                              www.ChikaraDev.com
                              • 13. Re: Using addChild() in an ActionScript vs. in a Class
                                Hi Greg,
                                and herein lies the dilemma - if I put import mx.core.UIComponent
                                into the package section before the constructor I'm back where I
                                started: undefined messages for addCHild, removeChild and
                                fileReference at compile time.
                                Scott
                                • 14. Re: Using addChild() in an ActionScript vs. in a Class
                                  Flex harUI Adobe Employee
                                  You can't call addChild in a static method.  A Class's static methods and
                                  properties do not belong to any instance, and only instances can have
                                  children.  You can pass an instance into a static methods and call addChild
                                  on that instance if you want.
                                  • 15. Re: Using addChild() in an ActionScript vs. in a Class
                                    Hi Aley,
                                    thanks for the replay.
                                    I removed the static keyword and that cleared up all of the problems except one.
                                    The compiler still flags fileReference as undefined.
                                    Mind you, this script works as a normal ActionScript object.
                                    Scott
                                    • 16. Re: Using addChild() in an ActionScript vs. in a Class
                                      I don't see it defined in your code.  You'll probably need to import
                                      FileReference and make an instance variable called fileReference.
                                      • 17. Re: Using addChild() in an ActionScript vs. in a Class
                                        Thanks Alex,
                                        the class compiles now.
                                        I've been experimenting around so much that I inadvertently removed one of the most
                                        important Imports.
                                        Scott
