1 Reply Latest reply on Feb 10, 2010 8:05 AM by Ben M
    Form Fields Question
    helpvid Level 2
      1. Which attribute can you use to preselect an item in a Radio Button list in a Forum.
      2. Which of the following fields requires a Value, Text Box - Radio Button - Checkbox - Pulldown menu.  I was thinking this was simple and the answer was Text Box, however i have never worked with Pull down so kind of threw me off.
        • 1. Re: Form Fields Question
          Ben M Adobe Community Professional
          1. If you click on the Radio button in the Properties window you can select this option for a default checked option without having to code.  Otherwise you will need to add: checked="checked"
          2.Nothing requires a value unless you specify for it to require a value through a validation process.  Then any field can be required to have a value.
