3 Replies Latest reply on Feb 10, 2010 12:05 PM by Harbs.
    AdjustLayout script error
    Fred Goldman Level 3
      I am often getting an error when I try to use the AdjustLayout script I decided to investigate and it turns it the problem is with these lines 117-120:
          var myStartPage = app.activeDocument.pages.item(myStartPageName);
          var myEndPage = app.activeDocument.pages.item(myEndPageName);
          //Set page numbering to absolute
          app.generalPreferences.pageNumbering = PageNumberingOptions.absolute;
      Apparently, when setting to absolute numbeing it makes the variables that previously pointed to valid pages invalid. Does anyone know of any workarounds to this?
      Just to be clear I get the error when I have the document start on an even number and it does not have Automatic Page Numbering selected.
        • 1. Re: AdjustLayout script error
          AdobeScripts Level 3
          You need to read and store documentOffset value for both pages - then you can use it later to get reference to the same physical page.
          robin
          www.adobescripts.com
          • 2. Re: AdjustLayout script error
            Perfect!
            Thanks you. Someone should tell Ole so that he can fix it for CS5..
            • 3. Re: AdjustLayout script error
              Harbs. Level 6
              Hi Fred,
              This is a common problem which pops up in various cases. You can use
              getElements()[0] to resolve the object to the id based one...
              Harbs
