0 Replies Latest reply on Feb 10, 2010 7:51 AM by sk_acura
    unbale to create editor ID in Flex Builder A5 Linux
    sk_acura
      Hi All,
        I am using the A5 Release of Flex Builder (flexbuilder_linux_install_a5_112409.bin) and using the Flex SDK (flex_sdk_3.5.0.12683)
      On Ubuntu 9.10 and when i try to open an MXML File i am getting the following Error:
      [CODE]
      org.eclipse.jface.util.Assert$AssertionFailedException: Assertion failed:
          at org.eclipse.jface.util.Assert.isTrue(Assert.java:179)
          at org.eclipse.jface.util.Assert.isTrue(Assert.java:164)
          at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.setActivePage(FlexMu ltiPageEditorPart.java:569)
          at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.setActivePage(CodeAndDesi gnEditor.java:647)
          at com.adobe.flexbuilder.editors.mxml.MXMLEditor.setActivePage(MXMLEditor.java:487)
          at com.adobe.flexbuilder.editors.derived.editor.FlexMultiPageEditorPart.createPartControl(Fl exMultiPageEditorPart.java:235)
          at com.adobe.flexbuilder.editors.common.editor.CodeAndDesignEditor.createPartControl(CodeAnd DesignEditor.java:162)
          at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
          at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
          at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
          at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:286)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2857)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
          at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
          at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
          at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu.java:344)
          at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMenu.java:192)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3493)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3112)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      [/CODE]
        Also after switching from Flex SDK 3.0 i have to manually import all the packges in flash.* ( which was not required with sdk 3.0)
        Any suggestions ??
      sateesh
