2 Replies Latest reply on Feb 12, 2010 10:11 AM by iamiqbal
    Populate data grid with java collection
    iamiqbal
      Hello:
      I am trying to populate data grid with return value obtained from java method invocation.
      Java method returns collection of java data objects.
      When i debug i can see that collection of objects are available in flex resultevent.
      How to set this into my datagrid.
      [Bindable]
      private var dataVar:ArrayCollection;
      private function displayList(evt:ResultEvent):void {
      dataVar = evt.result;  // This line is showing compile error
      calcTime();
      <mx:DataGrid
      id="data" dataProvider="{dataVar}"/>
      Also if anyone can let me know how to populate data grid dynamically. I mean the number of columns and rows are not known
      until i run the application. When i run the application and click on button it gets columns / rows and populates data grid.
      Appreciate any inputs on this.
      Iqbal.M
        • 1. Re: Populate data grid with java collection
          yoav@cyteam.com
          If your dataVar  is assigned as the  dataProvider for your DataGrid  then you can:
          In your result handler either:
          1.)  Process the the result.data  array item by item and add them using dataVar.addItem()
          for this you will need to initially allocation a  new ArrayCollection   ( e.g. dataVar = new ArrayCollection() )
          2.)  If you are certain that the result.data has the proper structure you can use it in the ArrayCollection constructor
          var itemsArray:Array = result.data as  Array;
          dataVar = new ArrayCollection(itemsArray);
          • 2. Re: Populate data grid with java collection
            iamiqbal Level 1
            I got it working.
            This is how i have achieved.
            Thanks for the reply.
            Bindable]
            var len:int = evt.result.length;
            textField.text+=len;
            var tempData:ArrayCollection = new ArrayCollection();
            dataVar =
            for(var i:int=0;i<len;i++)
            dataVar.addItem(evt.result[i]);
            <mx:DataGrid id="data" dataProvider="{dataVar}"/>
