0 Replies Latest reply on Feb 10, 2010 9:33 AM by Carol L. Frampton
    [svn:fx-trunk] 14095: Merge 14076 from 4.x branch to trunk.
    Carol L. Frampton Level 2
      Revision: 14095
      Revision: 14095
      Author:   cframpto@adobe.com
      Date:     2010-02-10 09:33:30 -0800 (Wed, 10 Feb 2010)
      Log Message:
      Revision: 14076
      Date:     2010-02-09 15:23:15 -0800 (Tue, 09 Feb 2010)
      Log Message:
      Add UIComponent.mapKeycodeForLayoutDirection().  This should be called by any keyDownHandlers() which handles Keyboard.LEFT and Keyboard.RIGHT, and optionally for Keyboard.UP and Keyboard.DOWN, if they behave like Keyboard.LEFT and Keyboard.RIGHT.  If the layoutDirection="rtl", it maps LEFT to RIGHT, RIGHT to LEFT, UP to RIGHT and DOWN to LEFT.  This allows the keyDownHandler() to perform the correct action without adding lots of special case code to the key handling code.
      QE notes: For layoutDirection="rtl" need to test LEFT, RIGHT, UP and DOWN keys.
      Doc notes: None
      Bugs: SDK-25330
      Reviewed By: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25330
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/CalendarLayout.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/HScrollBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/RadioButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Tree.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/colorPickerClasses/SwatchPan el.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/SliderThumb.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RadioButton.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Spinner.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBarBas e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SliderBase.a s
      Property Changed:
