3 Replies Latest reply on Apr 22, 2011 6:16 AM by Sébastien VARLET
    Error: Find criteria must contain at least one sort field value.
    jmc42
      Hi
      I am getting the followng error in Sort.as when I click on a column in a DataGrid that is bound to a nested property (e.g. parent.name)
      I can see why this is failing.
      In the findItem function of Sort.as the code tests whether there is data in line (456) hasFieldName = values[fieldName] !== undefined. This fails and so an error is raised later in the function by:
           if (fieldsForCompare.length == 0)
           message = resourceManager.getString(
      "collections", "findRestriction");
                throw new SortError(message);
      The code needs to traverse down the object hierarchy to get the field so that error is not thrown .
      In the case of a non nested property, everything works fine.
      There is lots of discussion about nested properties in DataGrid and there is this jira:
      http://bugs.adobe.com/jira/browse/SDK-9801
      There is talk of using a labelFunction or an itemRenderer and other third party solutions (extensions of DataGridColumn).
      Is this a bug?  is there a workaround using labelFunction or itemRenderer which can stop the error in Sort.as?
      James
      Here is the code of findItem in Sort.as of SDK 3..4.0.9271
      public
      function findItem(items:Array,
      values:Object,
      mode:String,
      returnInsertionIndex:Boolean =
      false,
      compareFunction:Function =
      null):int
      var compareForFind:Function;
      var fieldsForCompare:Array;
      var message:String;
      if (!items)
      "collections", "noItems");
      else if (items.length == 0)
      return returnInsertionIndex ? 1 : -1;
      if (compareFunction == null)
      compareForFind =
      this.compareFunction;
      // configure the search criteria
      if (values && fieldList.length > 0)
      fieldsForCompare = [];
      //build up the fields we can compare, if we skip a field in the
      //middle throw an error. it is ok to not have all the fields
      //though
      var fieldName:String;
      var hadPreviousFieldName:Boolean = true;
      for (var i:int = 0; i < fieldList.length; i++)
      fieldName = fieldList[i];
      if (fieldName)
      var hasFieldName:Boolean;
      try
      undefined;
      catch(e:Error)
      hasFieldName =
      false;
      if (hasFieldName)
      if (!hadPreviousFieldName)
      "collections", "findCondition", [ fieldName ]);
      else
      fieldsForCompare.push(fieldName);
      else
      hadPreviousFieldName =
      false;
      else
      //this is ok because sometimes a sortfield might
      //have a custom comparator
      null);
      else
      try
      initSortFields(items[0]);
      catch(initSortError:SortError)
      //oh well, use the default comparators...
      else
      compareForFind = compareFunction;
