9 Replies Latest reply on Feb 12, 2010 4:27 AM by Sherwette.Mansour
    Drag and Drop Image
    Sherwette.Mansour
      I am trying to drag and drop and image from a datagrid list component to a canvas, however, when I drop, it disappears! I need it to be copied in the canvas and can be dragged anytime in the canvas.
      Here is my code
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"
      name="Drag and Drop Tutorial"
      creationComplete="init()"
      initialize="pictureService.send()">
      <mx:Script>
      <![CDATA[
      import mx.controls.Image;
      import mx.core.DragSource;
         import mx.core.IUIComponent;
         import mx.managers.DragManager;
         import mx.events.DragEvent;
         import mx.controls.Alert;
         import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      import mx.collections.ArrayCollection;
      [Bindable] private var pictureData:ArrayCollection;
                  private function resultHandler(event:ResultEvent):void{
                  pictureData = event.result.data.image;
                  private function faultHandler(event:FaultEvent):void{
                  //code
      public function init():void
                  // a mouseDown event will start the drag
            list.dataProvider = pictureData;
            //picture in the list is being dragged
             this.picture.addEventListener( MouseEvent.MOUSE_DOWN, beginDrag );
             // accepting a drag/drop operation...
           this.area.addEventListener( DragEvent.DRAG_ENTER, acceptDrop );
           // handling the drop...
            this.area.addEventListener( DragEvent.DRAG_DROP, handleDrop );
               public function beginDrag( mouseEvent:MouseEvent ):void
           // the drag initiator is the object being dragged (target of the mouse event)
             var dragInitiator:IUIComponent = mouseEvent.currentTarget as IUIComponent;
            // the drag source contains data about what's being dragged
            var dragSource:DragSource = new DragSource();
            // / Add the data to the object.
                      dragSource.addData(1, 'value');
                     /*  dragSource.addData(dragInitiator, "items"); */
                      // Create a copy of the coin image to use as a drag proxy.
                     var dragProxy:Image = new Image();
                      dragProxy.source = mouseEvent.currentTarget.source;
                      dragProxy.setActualSize(mouseEvent.currentTarget.width,mouseEvent.currentTarget.height)
            // ask the DragManger to begin the drag
            DragManager.doDrag( dragInitiator, dragSource, mouseEvent, dragProxy );
      public function acceptDrop( dragEvent:DragEvent ):void
             var dropTarget:IUIComponent = dragEvent.currentTarget as IUIComponent;
            // accept the drop
            DragManager.acceptDragDrop( dropTarget );
            // show feedback
            DragManager.showFeedback( DragManager.COPY );
              if(dragEvent.dragSource.hasFormat("items"))
         var items:Array = dragEvent.dragSource.dataForFormat("items") as Array;
         trace(items[0].src);
         var img:Image = new Image()
         img.x=dragEvent.localX
         img.y=dragEvent.localY
         img.source=items[0].src
         img.addEventListener(MouseEvent.MOUSE_MOVE,beginDrag);
         area.addChild(img);
         else
         //makes an object moves
         dragEvent.dragInitiator.x=dragEvent.localX
         dragEvent.dragInitiator.y=dragEvent.localY
           public function handleDrop( dragEvent:DragEvent ):void
            var dragInitiator:IUIComponent = dragEvent.dragInitiator;
         public var xOff:Number;
                  public var yOff:Number;
      </mx:Script>
         <mx:HTTPService id="pictureService"
      url="data/data.xml"
      result="resultHandler(event)"
      fault="faultHandler(event)"/>
      <mx:DataGrid id="list" width="238" height="200" y="26" x="10" labelField="src" dragEnabled="true"
      dataProvider="{pictureData}">
        <mx:columns>
        <mx:DataGridColumn dataField="id" id="code">
        </mx:DataGridColumn>
        <mx:DataGridColumn id="picture" draggable="true" >
        <mx:itemRenderer>
        <mx:Component>
        <mx:Image source="assets/{data.id}.jpg"  />
        </mx:Component>
        </mx:itemRenderer>
      </mx:columns>
      </mx:DataGrid>
      <mx:Canvas id="area" x="266" y="28" width="436" height="401" backgroundColor="#c0c0c0"
      dragDrop="handleDrop(event)" >
      </mx:Canvas>
      </mx:Application>
      I'd really appreciate your help in this.
        • 1. Re: Drag and Drop Image
          Flex harUI Adobe Employee
          I would expect handleDrop to create an instance of something and call
          addChild()
          • 2. Re: Drag and Drop Image
            Sherwette.Mansour Level 1
            I have added this code to HandleDrop, but it still disappears.
                  var newImage:Image = new Image();
                  var dropCanvas:Canvas = dragEvent.currentTarget as Canvas;
                  dropCanvas.addChild(newImage);
            The application is attached.
            Thanks for the reply
            Sherwette
            • 3. Re: Drag and Drop Image
              Gregory Lafrance Level 6
              If this post answers your question or helps, please mark it as such.
              Greg Lafrance - Flex 2 and 3 ACE certified
              www.ChikaraDev.com
              Flex / AIR Development, Training, and Support Services
              The following code works. Notice the following in my code:
              I add the MouseDown event handler to the Image item renderer, because if you add it to the datagrid column, well it does not have a source property, or at least it is not the dragged image, so that won't work.
              Also notice I ripped som code out of your acceptDrop function and put it in the handleDrop function where it should be.
              I also don't know why you were expecting the data in the dataSource to be an array. Its just the source of the dragged image, so its just a string.
              I also set the width and height of the image to add.
              So your code was a little confusing, but like I said, it works (10 points please ).
                layout="vertical" name="Drag and Drop Tutorial"
                creationComplete="init()" initialize="pictureService.send()">
                <mx:Script>
                  <![CDATA[
                      //code
                    public function init():void{
                    public function beginDrag( mouseEvent:MouseEvent ):void{
                      //dragSource.addData(1, 'value');
                      dragSource.addData(mouseEvent.currentTarget.source, "items");
                    public function acceptDrop( dragEvent:DragEvent ):void{
                      if (dragEvent.dragSource.hasFormat("items")){
                        DragManager.acceptDragDrop(Canvas(dragEvent.currentTarget));
                    public function handleDrop( dragEvent:DragEvent ):void{
                      var items:String = dragEvent.dragSource.dataForFormat("items") as String;
                      var img:Image = new Image();
                      img.x=dragEvent.localX;
                      img.y=dragEvent.localY;
                      img.width = 50;
                      img.height=50;
                      img.source=items.toString();
                      area.addChild(img);
                </mx:Script>
                <mx:HTTPService id="pictureService" url="data/data.xml"
                  result="resultHandler(event)" fault="faultHandler(event)"/>
                  dragEnabled="true" dataProvider="{pictureData}">
                  <mx:columns>
                    <mx:DataGridColumn dataField="id" id="code"/>
                      <mx:itemRenderer>
                        <mx:Component>
                          <mx:Image source="assets/{data.id}.png" mouseDown="outerDocument.beginDrag(event)"/>
                        </mx:Component>
                      </mx:itemRenderer>
                  </mx:columns>
                </mx:DataGrid>
                <mx:Canvas id="area" width="436" height="401"
                  backgroundColor="#c0c0c0" dragDrop="handleDrop(event)" >
                </mx:Canvas>
              </mx:Application>
              • 4. Re: Drag and Drop Image
                Thank you Thank you for your assistance in my matter.
                I have tried to follow your adjustments to the code, though there is no compile error, there is runtime error as follows:
                TypeError: Error #1009: Cannot access a property or method of a null object reference.
                at DragDropHopeTutorial4/handleDrop()[C:\Users\Shoushou\Documents\Flex Builder 3\DragDropHopeTutorial\src\DragDropHopeTutorial4.mxml:120]
                at DragDropHopeTutorial4/__area_dragDrop()[C:\Users\Shoushou\Documents\Flex Builder 3\DragDropHopeTutorial\src\DragDropHopeTutorial4.mxml:162]
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.core::UIComponent/dispatchEvent()[E:\dev\3.0.x\frameworks\projects\framework\src\mx\co re\UIComponent.as:9051]
                at mx.managers.dragClasses::DragProxy/mouseUpHandler()[E:\dev\3.0.x\frameworks\projects\fram ework\src\mx\managers\dragClasses\DragProxy.as:500]
                line 120: img.source=items.toString();
                inside handleDrop function
                and
                line162: <mx:Canvas id="area" x="266" y="28" width="436" height="401" backgroundColor="#c0c0c0"
                I know my code is a little confusing, because I am just a beginner and I use the internet as my reference. So, please if you know any advanced tutorials for flex online, please advice me.
                Thank you
                • 5. Re: Drag and Drop Image
                  I have tried to debug the code, and i narrowed it down to this line.
                  in the handleDrop function, apparently there is a problem with the source and string, but I can't figure it out. Please I really appreciate your help in this.
                  Thank you
                  • 6. Re: Drag and Drop Image
                    Items is an array.  Try items[0].toString(), but it really matters what
                    items[0] is and what field you want to pull.
                    • 7. Re: Drag and Drop Image
                      I changed items to a type of Object.
                      var items:Object = dragEvent.dragSource.dataForFormat("items") ;
                      Now, when its dropped, it shows an unavailable image.
                      • 8. Re: Drag and Drop Image
                        Items is an Array, not an object.  Try something like this:
                        IUIComponent;
                        Array;
                                img.width = 50;
                                img.height=50;
                                img.source="assets/" + items[0].id + ".png";
                                area.addChild(img);
                        • 9. Re: Drag and Drop Image
                          It worked! Thank you very much
