4 Replies Latest reply on Feb 15, 2010 10:02 AM by jay fresno
    index problem
    jay fresno Level 2
      Posting on the scripting forum because InDesign CS4 doesn't seem to be able to do this out of the box.
      Need to have an index with listings, for example:
      ANIMALS
        cats 3
        dogs  6
        penguins  4
        see also zebras
      The problem is with the 'see also' listing. InDesign keeps putting it in the wrong place, and doesn't seem to be able to add it as a level 2 index entry.
      Can any of you gurus suggest a workaround?
        • 1. Re: index problem
          Peter Kahrel Adobe Community Professional & MVP
          What you can do is rather than real cross-references, create sub-topics and call them "z_see_ abc" and "z_see also_ xyz". They're then generated as separate level-2 entries with a page number. The "z" in "z_see_ abc" ensures that they're sorted after the subtopics. The underscores are just a way to find "see" and "see also" so that you can apply a character style to them. The page numbers can be removed with this Grep:
          Find: (^_see( also)?_.+?)[\s\d]+$
          Change to: $1
          but do this before adding the character styles.
          Peter
          • 2. Re: index problem
            jay fresno Level 2
            Peter,
            I very much appreciate your suggestion. It seems like it should work -- what am I doing wrong?
            I get the following message:
            The sample index looks like this:
            The Find/Change looks like this:
            • 3. Re: index problem
              Sorry Jay, that should have been this (forgot about the z):
              ^z(_see( also)?_.+?)[\s\d]+$
              To add italics to _see_ and _see also_, do this:
              Find what: _([^_]+)_
              Change to: $1
              (and set italics in the "Change format" pane.
              Peter
              • 4. Re: index problem
                jay fresno Level 2
                Peter,
                Thank you so much for your solution and for taking the time to help. This time it is working perfectly.
