1 Reply Latest reply on Feb 11, 2010 7:01 AM by yoav@cyteam.com
    Tile List Frustration
    bentwonk
      I am tring to create a simple tile list as part of an AS3 class, haveing looked at a few examples I do not seem to be able to populate it with data, neither addItem or dataPopulator seem to available to me, when using AS3 code.
      using the simplest exampe I could find, (http://www.adobe.com/devnet/flash/quickstart/tilelist_component_as3/)
      import fl.controls.TileList;
      import fl.controls.ScrollBarDirection;
      /* // these had to be changed to imports below to compile
      import mx.controls.TileList;
      import mx.controls.scrollClasses.ScrollBarDirection;
      private function tilelist():void
      // Create TileList instance
      var myTileList:TileList = new TileList();
      // Add four images to the TileList instance
      myTileList.addItem({label:"Montreal", source:"http://www.helpexamples.com/images/montreal/images/IMG_5057.jpg"});
      myTileList.addItem({label:"Swan", source:"http://www.helpexamples.com/flash/images/gallery1/images/pic11.jpg"});
      myTileList.addItem({label:"Sunset", source:"http://www.helpexamples.com/flash/images/gallery1/images/pic14.jpg"});
      myTileList.addItem({label:"Gate", source:"http://www.helpexamples.com/flash/images/gallery2/images/IMG_1592.jpg"});
      // Set scroll bar direction
      myTileList.direction = ScrollBarDirection.HORIZONTAL;
      // position TileList and set column and row values
      myTileList.move(0,0);
      myTileList.columnWidth = 200;
      myTileList.rowHeight = 140;
      myTileList.columnCount = 1;
      myTileList.rowCount = 2;
      myTileList.width = 200;
      myTileList.height = 295;
      // Add to the display (Stage)
      addChild(myTileList);
      fails to compile as the addItem method cannot be found
      tried with a dataProvider, instead of add item, but that cannot be found either, and what is the include file for a dataProvider
      whats am I doing wrong, and why do adobe not cover this in their example?
      thanks in frustratuion .
        • 1. Re: Tile List Frustration
          yoav@cyteam.com
          You need to provide the dataProvider which is an ArrayCollection on which you do your addItem opertions:
          private var myItemCollection:ArrayCollection = new ArrayCollection();
          then in you code you assign it to your TileList.
          myTileList.dataProvider = myItemCollection;
          and you can then add your items ..
          myItemCollection.addItem( .........)
