5 Replies Latest reply on Feb 12, 2010 12:04 AM by Peter Bossens
    Activate a profile in Live Preflight - JS
    Peter Bossens
      I would like to activate an existing Live Preflight profile for the active document.
      The code I have is:
      var myDocument=app.activeDocument;
      var ProfileName = "TestProfile";
      var process = app.preflightProcesses.add(myDocument, ProfileName);
      process.waitForProcess();
      results = process.processResults;
      But I get an error that the document is undefined, why?
      Peter
        • 1. Re: Activate a profile in Live Preflight - JS
          Shonkyin Level 3
          Hi Peter,
          You can generate the report if error found. Please see below code:
          var profile = app.preflightProfiles.add();
          profile.name = "Test";
          profile.description = "Test description";
          const RULE_NAME = "ADBE_PageSizeOrientation";
          var rule = profile.preflightProfileRules.add(RULE_NAME);
          //Requires the page size to be 8.5 in x 11in (Letter Size)
          //enters a value for tolerance
          rule.ruleDataObjects.add("tolerance", RuleDataType.realDataType, 0.01);
          //Sets the width  to the point equivalent of 8.5 inches
          rule.ruleDataObjects.add("width", RuleDataType.realDataType, 612);
          // Sets the width  to the point equivalent of 11 inches
          rule.ruleDataObjects.add("height", RuleDataType.realDataType, 792);
          //true = ignore orientation is checked
          rule.ruleDataObjects.add("ignore_orientation", RuleDataType.booleanDataType, true);
          //set the rule to return an error
          rule.flag = PreflightRuleFlag.returnAsError;
          //Process the doc with the rule
          var process = app.preflightProcesses.add(myDocument, profile);
          //If Errors were found
          if (results != 'None')
              //Export the file to PDF
              //The “true” value selects to open the file after export.
              process.saveReport(File("~/Desktop/preflight.pdf"), true);
          Shonky
          • 2. Re: Activate a profile in Live Preflight - JS
            Shonkyin Level 3
            And here is your code:
            var process = app.preflightProcesses.add(myDocument, app.preflightProfiles.item('TestProfile'));
            I hope it will help you.
            Shonky
            • 3. Re: Activate a profile in Live Preflight - JS
              Peter Bossens Level 1
              Shonkyin,
              Yes, that works!
              Just one more thing: the script uses the right profile to create the report, but afterwards, another ("[Basic] (working)") profile is visible in the palette.
              Is there a way to activate a specific profile in InDesign's Live Preflight palette?
              Peter
              • 4. Re: Activate a profile in Live Preflight - JS
                Shonkyin Level 3
                app.preflightOptions.preflightOff = false;
                myDocument.preflightOptions.preflightWorkingProfile= 'TestProflie'
                Shonky
                • 5. Re: Activate a profile in Live Preflight - JS
                  Shonky,
                  Yes, perfect, thanks a lot!
                  Peter
