0 Replies Latest reply on Feb 11, 2010 9:53 AM by Carol L. Frampton
    [svn:fx-trunk] 14124: Merge 14123 from 4.x branch to trunk.
    Carol L. Frampton Level 2
      Revision: 14124
      Revision: 14124
      Author:   cframpto@adobe.com
      Date:     2010-02-11 09:53:35 -0800 (Thu, 11 Feb 2010)
      Log Message:
      Log Message:
      Two additions/corrections to 14076.  Add key mappings for layoutDirection="rtl" for spark list components.  Correct type of keyCode variable so it is an uint rather than an int to match event.keyCode.
      BitmapImage has a hard-coded layout direction="ltr".
      QE notes: For layoutDirection="rtl" need to test LEFT, RIGHT, UP and DOWN keys.
      Doc notes: None
      Bugs: SDK-25330
      Reviewed By: Hans
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25330
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ButtonBar.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/CalendarLayout.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/Menu.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/RadioButton.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/Tree.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/colorPickerClasses/Sw atchPanel.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/listClasses/TileBase. as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/sliderClasses/SliderT humb.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/RadioButton.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/supportClasses/Butto nBarBase.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/supportClasses/DropD ownListBase.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/supportClasses/Slide rBase.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/primitives/BitmapImage.as
      Property Changed:
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/CalendarLayout.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Menu.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/RadioButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Tree.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/colorPickerClasses/SwatchPan el.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/SliderThumb.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/List.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RadioButton.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBarBas e.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownList Base.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SliderBase.a s
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/BitmapImage.as
      Property Changed:
