2 Replies Latest reply on Feb 11, 2010 5:17 PM by John Danek
    Good workflow to avoid white lines and discolored boxes with transperancy?
    j0sh3w1ng Level 1
      I'm somewhat new to Illustrator.  I have designs in illustrator CS4 that contain objects with drop shadows that are on top of gradient backgrounds.  When I save out the artwork as a PDF file I see random faint white lines and discolored boxes around the objects with the drop shadows.  When I print proofs of the file on my HP3500 color laser printer I see the white lines and discolored boxes as well.  I'm afraid the the lines will show up in production when I send off to the printer. Here's what I'm doing.  Any suggestions would be appreciated.
      (Document Raster Effects Settings: Resolution-High 300ppi/Background: Transperant/Options: preserve spot colors, add 12.7mm around object)
      1. Save file as PDF from Illustrator CS4
      2. PDF Settings
           a. PDF Preset: PDF /xa:2001
           b. Advanced Overprint and Transperancy flatener options: Preset-High Resolution
      When viewed and printed from Adobe Acrobat 9 Pro there are white stiching lines that are visible.
      Do I need to worry about these? Or will they go away when sent to a better printer?
      Thanks for the help.
