4 Replies Latest reply on Feb 11, 2010 2:34 PM by CrazyMerlin
    Package/Class name resolution issue
    CrazyMerlin Level 1
      Hey guys!
      I have an application called Infused. I also have a package called Managers with a class called DataManager which extends HTTPService.
      In a function in DataManager I need to call a public function that exists in Infused.
      Now, if the application is called Infused, then it's default class must be called Infused too, right?
      But when I called Infused.loginResult(evt) I get the error: Access of possibly undefined method loginResult through a reference with static type Class.
      I assumed the applications class would be in the global namespace and accessible. Am I wrong? And if so how can I call the function?
      Also, in the applications main class I have a number of functions called xxxResult which I need to call depending on a string that is passed in to the class request function. So the request function may receive 'login', and so the function to call in Infused would be 'loginResult'.
      How can I call the function based on this string? I know I could do Class[functionName]() if the function where in the same class, but will the answe to my first question lead to the obvious solution for the second?
      I am a PHP5 OOP developer learning Flex, so please forgive my dumbassness
      Thanks for any help.
      Paul.
        • 1. Re: Package/Class name resolution issue
          msakrejda Level 4
          You can't call instance methods like that. You'd need to make the method static, or alternately, call Infused(Application.application).loginResult(evt). After you make either change, you should be able to use the ['functionName']() approach.
          Keep in mind, though, that you're coupling your DataManager to your application with this approach. This might be fine for a small app, but take a look at Mate (or some of the other MVC frameworks) to see how to reduce or avoid this sort of coupling.
          • 2. Re: Package/Class name resolution issue
            CrazyMerlin Level 1
            The initial app was built around a thought process as I am just learning AS3 in Flex, and is quite small. I will make sure to MVC the final app once I have a better understanding of the approaches to this in AS3.
            However, what you suggested doesn't seem to work. If I make the method static, then I cannot reference the MXML components. If I tru to call Infused(Application.application).loginResult() I get a "Access of undefined property Application" error.
            Any thoughts?
            • 3. Re: Package/Class name resolution issue
              msakrejda Level 4
              If your handlers are referencing components within the app, you're right--static is not an option. The other approach should work, though. Perhaps you need to import mx.core.Application?
              • 4. Re: Package/Class name resolution issue
                CrazyMerlin Level 1
                Ah finally, I can separate my data logic!
                Thanks man, I had imported mx.core.Application
                << a contented developer!
