1 Reply Latest reply on Feb 12, 2010 5:40 AM by Gregory Lafrance
    External Links
      Hey everybody,
      I'm just trying to create my first simple app with adobe air. I followed one of the adobe tutorials which helped me setup the app with simple functionality like close and minimize button.
      What I need to do is import links on to the application screen. The links need to be located inside a txt file so people can change them. Is something like that possible? I tried putting an as3 code for it, but it doesn't seem to work, even tho if I create blank as3 document it works. Just not under Air document.
      Any help would be much appreciated.
        • 1. Re: External Links
          Gregory Lafrance Level 6
          If this post answers your question or helps, please mark it as such.
          Greg Lafrance - Flex 2 and 3 ACE certified
          Flex / AIR Development, Training, and Support Services
          Here you go.
          Create a file in the users documents directory with this text:
          <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
                import mx.controls.LinkButton;
                import mx.controls.Alert;
                import flash.filesystem.*;
                import mx.events.*;
                private var currentFile:File;
                private var stream:FileStream = new FileStream();
                private var defaultDirectory:File;
                [Bindable] public var dataChanged:Boolean = false;
                private function appCompleteHandler():void {
                  defaultDirectory = File.documentsDirectory;
                  stage.nativeWindow.width = 500;
                  stage.nativeWindow.height = 400;
                  stage.nativeWindow.visible = true;
                private function openFile():void {
                  var fileChooser:File;
                  if (currentFile) {
                    fileChooser = currentFile;
                    fileChooser = defaultDirectory;
                    fileChooser.addEventListener(Event.SELECT, fileOpenSelected);
                private function fileOpenSelected(event:Event):void
                  currentFile = event.target as File;
                  stream = new FileStream();
                  stream.openAsync(currentFile, FileMode.READ);
                  stream.addEventListener(Event.COMPLETE, fileReadHandler);
                  stream.addEventListener(IOErrorEvent.IO_ERROR, readIOErrorHandler);
                private function fileReadHandler(event:Event):void
                  var str:String = stream.readUTFBytes(stream.bytesAvailable);
                  var lineEndPattern:RegExp = new RegExp(File.lineEnding, "g");
                  str = str.replace(lineEndPattern, "\n");
                  var arr:Array = str.split("\n");
                  for each(var line:String in arr){
                    var lb:LinkButton = new LinkButton();
                    lb.label = line;
                    lb.addEventListener(MouseEvent.CLICK, clickFunc);
                private function clickFunc(evt:MouseEvent):void{
                  navigateToURL(new URLRequest(evt.currentTarget.label),"_blank");
                private function readIOErrorHandler(event:Event):void
                  mx.controls.Alert.show("Specified file cannot be opened.", "Error", Alert.OK, this);
            <mx:Button label="Open Links" id="openBtn" click="openFile()"/>
            <mx:VBox id="vb" width="100%" height="100%"/>
