0 Replies Latest reply on Feb 11, 2010 4:36 PM by kevinklin
    [svn:fx-trunk] 14139: Fix for Player classes not code hinting  to framework FB projects.
    kevinklin Adobe Employee
      Revision: 14139
      Revision: 14139
      Author:   klin@adobe.com
      Date:     2010-02-11 16:36:39 -0800 (Thu, 11 Feb 2010)
      Log Message:
      Fix for Player classes not code hinting  to framework FB projects. Changed all the $ tokens to use $ instead. While the compiler understands $, Flash Builder's code model does not.
      No code changes.
      QE notes: N/A
      Doc notes: N/A
      Bugs: None
      Reviewer: Pete
      Tests run: checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/airspark/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/flex/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/framework/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/osmf/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/rpc/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/spark/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/sparkskins/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/textLayout/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/wireframe/.actionScriptProperties
