2 Replies Latest reply on Feb 15, 2010 12:25 AM by tof69
    Path to a file with a Mac
      I create a application for PC with Air which works fine. It load external pdf files.
      I need to create it for mac too, but i have a problem with path on mac.
      here is a exemple of trace done on mac :
      (String) =/Applications/Urgo/URGO Book.app/Contents/Resources/data/files/URGO/01 - DONNÉES MARCHÉ/01 - Argumentaire Urgo.pdf
      Has you can see there are french characters and space in the path.
      But it's works on PC so is it the real problem?
        • 1. Re: Path to a file with a Mac
          Gregory Lafrance Level 6
          What exactly is the problem are you experiencing, and what code seems to be the issue?
          • 2. Re: Path to a file with a Mac
            tof69 Level 1
            Hello Greg,
            here is the function for launching a pdf im my application :
            public static function creationPdf(fichier:File ):void
                        var request:URLRequest = new URLRequest(fichier.url);
                        //MonsterDebugger.trace ( "Affichepdf_creationpdf", "request :" + fichier.nativePath);        //trace on the previous message
                        _pdfExist = true;
            To be compatible with a mac the path MUST have no french character an NO space...
            How can I do to get same result as the PC.
            As you can see I use the property "url" I try with nativePath too.
            I try wi the AIR 2.0 framework and it's the same thing....
