1 Reply Latest reply on Feb 13, 2010 5:58 AM by try67
    Calculation that results in a 0 is null
    Working for a living Level 1
      Hi:
      I have an issue when the results of a calculation = 0, the field is considered to have a null value.
      For example:
      I have a number of columns and rows in a table.
      the desired result is to have the last entry in the table as the first entry in the next table.
      the last entry column has a calculation in each row of
      var a = this.getField("JanE.5");
      var b = this.getField("JanF.5");
      var c = this.getField("JanG.5");
      var d = this.getField("JanDay.5").value;
      if(d != "")
      event.value = a.value - b.value - c.value;
      else
      event.value="";
      In the first column of the second table selects the last row of the first table that has a value and takes its value.
      var a = this.getField("JanH.5").value;
      var b = this.getField("JanH.4").value;
      var c = this.getField("JanH.3").value;
      var d = this.getField("JanH.2").value;
      var e = this.getField("JanH.1").value;
      var f = this.getField("JanH.0").value;
      if(a == 0 || a > 0 && b == 0 || b > 0 && c == 0 || c > 0 && d == 0 || d > 0 && e == 0  || e > 0 && f == 0 || f > 0)
      event.value = a || b || c || d || e || f
      This works for all values except when the calculation = 0.  In this case it selects the next value
      Table 1 values are
      ("JanH.5").value - Null
      ("JanH.4").value - 0
      ("JanH.3").value - 1
      ("JanH.2").value - 102
      ("JanH.1").value - 1101
      ("JanH.0").value - 5545
      The value for the field is 1 when it should be 0.  this happens for all cells.
      How can I get the cell value to be 0 like it should be?
      I tried multiplying the values by 1 to force it to a numeric 0 value but this doesnt work.
      Thanks for your help...
