0 Replies Latest reply on Feb 12, 2010 1:24 PM by HansMuller
    [svn:fx-4.x] 14151:
    HansMuller
      Revision: 14151
      Revision: 14151
      Author:   hmuller@adobe.com
      Date:     2010-02-12 13:24:04 -0800 (Fri, 12 Feb 2010)
      Log Message:
      Revised mirroring support for popups in DropDownList and ComboBox.
      UIComponent/invalidateLayoutDirection() now assumes that a component without an IVisualElement parent inherits a LTR coordinate system.
      PopUpAnchor uses MatrixUtil.getConcatenatedMatrix() - which concatenates UIComponent layoutMatrix - for layout computations and MatrixUtil.getConcatenatedComputedMatrix() to find the stage coordinates of a popup's origin.
      Sync'd MX ListBase/validateDisplayList(), which is a copy of UIComponent/validateDisplayList() with validateMatrix() changes made
      in the UIComponent version.
      QE notes: Full Mustella run was OK (thanks Joan!)
      Doc notes:
      Bugs:
      Reviewer: Jason
      Tests run:
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/controls/listClasses/ListBase. as
          flex/sdk/branches/4.x/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/branches/4.x/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
