0 Replies Latest reply on Feb 12, 2010 2:52 PM by Jason Szeto
    [svn:fx-trunk] 14157: Merge 4.0 revision 14154 -> trunk
    Jason Szeto Level 3
      Revision: 14157
      Revision: 14157
      Author:   jszeto@adobe.com
      Date:     2010-02-12 14:51:50 -0800 (Fri, 12 Feb 2010)
      Log Message:
      Recording the merge, but not performing the actual merge since this has already been merged from the 4.x branch.
      Original revision notes:
      PopUpAnchor bug fix for Marshall Plan
      http://bugs.adobe.com/jira/browse/SDK-25348 - Marshall Plan rendering error in AIR
      The fix is to replace PopUpAnchor.getPopUpMatrix() with MatrixUtil.getComputedMatrix(this).
      The PopUpAnchor needs to place the popUp relative to the SystemManager that is attaching the popUp. MatrixUtil.getComputedMatrix will stop at the correct displayList parent regardless if it is a trusted or untrusted sub app.
      QE notes: Add test case to mustella for this bug Doc notes: none
      Bugs: SDK-25348
      Reviewer: Alex
      Tests run: PopUpAnchor, DropDownList, ComboBox Is noteworthy for integration: No
      Ticket Links:
      Property Changed:
          flex/sdk/trunk/
          flex/sdk/trunk/frameworks/
