0 Replies Latest reply on Feb 12, 2010 6:03 PM by pchrono
    FDF with SSL source PDF URL
    pchrono
      Having a problem With the latest version of Reader 9 and FDF submissions.
      Opening an FDF file locally that contains  a /F entry pointing to a HTTS server URL ( for the source PDF to merge with ) works fine and merges PDF and FDF data however on further submission to another server  fails to include the source PDF URL in the FDF stream Reader creates.
      If the PDF source host server does not require SSL all works fine. With SSL the Reader submit function ( on the merged PDF ) sends an FDF stream without the /F of the source PDF. This also works fine with Reader 7.0 but not with newer versions ( or with SSL file hosts.)
      Using older Reader versions is not an option.
      Any ideas ?
      Thanks in advance.
