1. Re: AE Pro CS4 and VOB Files
Todd_Kopriva Feb 13, 2010 3:46 PM (in response to l1o1t1r1)VOB isn't a supported import format for After Effects.
Here's a search that brings up plenty of additional information.
from "Supported import formats":
"Some MPEG data formats are stored in container formats with filename extensions that are not recognized by After Effects; examples include .vob and .mod. In some cases, you can import these files into After Effects after changing the filename extension to one of the recognized filename extensions. Because of variations in implementation in these container formats, compatibility is not guaranteed."
2. Re: AE Pro CS4 and VOB Files
Mylenium Feb 14, 2010 1:54 AM (in response to l1o1t1r1)Rename them to MPG and try to open them in AE. Just make sure to have enough space in your media cache folder and be patient - VOB are multiplexed and AE needs a few moments to extract the audio and index the file on first load. If that doesn't work, convert the files to conventional AVIs using tools like TMPEG, MPEGStreamclip and so on...
Mylenium
3. Re: AE Pro CS4 and VOB Files
l1o1t1r1 Feb 14, 2010 2:14 AM (in response to l1o1t1r1)Thanks Todd been reading and trying different things from your first link which somehow got me to a freeware software (for pc) called Convert vob to avi 1.7 - I used the mpeg4 setting in the avi format. The program converted with no problems and AE Pro CS4 open it with no problems - being new to AE Pro CS4 I did not know how to get it to play so I opened the converted file in Premiere Pro CS4 and it played fine So I guess it will play in AE as soon as I learn how to get it to play in there.
Thanks for your help Mylenium - I tried the renaming but it did not work for me and found the the Convert vob to avi 1.7 freeware did a good for me.
