0 Replies Latest reply on Feb 14, 2010 5:08 AM by venkateshk
    Flex and Seam Integration
    venkateshk
      Hi I am using FlamingoDS to integrate seam with flex
      I have an entity called ItCargoPosition and one more entity called IcStorageNameDetail
      In ItCargoPosition entity
      private IcStorageNameDetail icStorageNameDetailByStorageName;
      private IcStorageNameDetail icStorageNameDetailByStorageRow;
      private IcStorageNameDetail icStorageNameDetailByStorageColumn;
      @ManyToOne(fetch = FetchType.LAZY)
          @JoinColumn(name = "STORAGE_NAME", nullable = false)
          @NotNull
          public IcStorageNameDetail getIcStorageNameDetailByStorageName() {
              return this.icStorageNameDetailByStorageName;
          public void setIcStorageNameDetailByStorageName(
                  IcStorageNameDetail icStorageNameDetailByStorageName) {
              this.icStorageNameDetailByStorageName = icStorageNameDetailByStorageName;
          @JoinColumn(name = "STORAGE_ROW", nullable = false)
          @NotNull
          public IcStorageNameDetail getIcStorageNameDetailByStorageRow() {
              return this.icStorageNameDetailByStorageRow;
          public void setIcStorageNameDetailByStorageRow(
                  IcStorageNameDetail icStorageNameDetailByStorageRow) {
              this.icStorageNameDetailByStorageRow = icStorageNameDetailByStorageRow;
          @JoinColumn(name = "STORAGE_COLUMN", nullable = false)
          @NotNull
          public IcStorageNameDetail getIcStorageNameDetailByStorageColumn() {
              return this.icStorageNameDetailByStorageColumn;
          public void setIcStorageNameDetailByStorageColumn(
                  IcStorageNameDetail icStorageNameDetailByStorageColumn) {
              this.icStorageNameDetailByStorageColumn = icStorageNameDetailByStorageColumn;
      and in IcStorageNameDetail I have
      private Set<ItCargoPosition> itCargoPositionsForStorageRow = new HashSet<ItCargoPosition>(
                  0);
          private Set<ItCargoPosition> itCargoPositionsForStorageName = new HashSet<ItCargoPosition>(
                  0);
          private Set<ItCargoPosition> itCargoPositionsForStorageColumn = new HashSet<ItCargoPosition>(
                  0);
      @OneToMany(fetch = FetchType.LAZY, mappedBy = "icStorageNameDetailByStorageRow")
          public Set<ItCargoPosition> getItCargoPositionsForStorageRow() {
              return this.itCargoPositionsForStorageRow;
          public void setItCargoPositionsForStorageRow(
                  Set<ItCargoPosition> itCargoPositionsForStorageRow) {
              this.itCargoPositionsForStorageRow = itCargoPositionsForStorageRow;
          @OneToMany(fetch = FetchType.LAZY, mappedBy = "icStorageNameDetailByStorageName")
          public Set<ItCargoPosition> getItCargoPositionsForStorageName() {
              return this.itCargoPositionsForStorageName;
          public void setItCargoPositionsForStorageName(
                  Set<ItCargoPosition> itCargoPositionsForStorageName) {
              this.itCargoPositionsForStorageName = itCargoPositionsForStorageName;
          @OneToMany(fetch = FetchType.LAZY, mappedBy = "icStorageNameDetailByStorageColumn")
          public Set<ItCargoPosition> getItCargoPositionsForStorageColumn() {
              return this.itCargoPositionsForStorageColumn;
          public void setItCargoPositionsForStorageColumn(
                  Set<ItCargoPosition> itCargoPositionsForStorageColumn) {
              this.itCargoPositionsForStorageColumn = itCargoPositionsForStorageColumn;
      the above are my entities
      and I have a created my own component to retrieve the details from the database
      as follows
      package com.infyz.toms.planning;
      import java.util.List;
      import javax.ejb.Stateless;
      import javax.persistence.EntityManager;
      import javax.persistence.PersistenceContext;
      import javax.persistence.PersistenceContextType;
      import org.jboss.seam.ScopeType;
      import org.jboss.seam.annotations.Logger;
      import org.jboss.seam.annotations.Name;
      import org.jboss.seam.annotations.Scope;
      import org.jboss.seam.log.Log;
      import com.infyz.toms.admin.configuration.cargooperations.entity.IcStorageName;
      import com.infyz.toms.ordermanagement.exportshipment.entity.ItCargoPosition;
      @Name("planservice")
      @Stateless
      public class PlanSession implements PlanInterface{
          @Logger
          private Log log;
          @PersistenceContext(type=PersistenceContextType.TRANSACTION)
          private EntityManager em;
          public List<ItCargoPosition> cargoPositionList()
              return em.createQuery("from ItCargoPosition").getResultList();
      In my mxml I am calling this method to get the values from the database
      <mx:HBox xmlns:mx="http://www.adobe.com/2006/mxml" backgroundColor="white" width="100%" height="100%" verticalGap="0"
          horizontalGap="0" initialize="cc();" creationComplete="service.cargoPositionList();">
          <mx:RemoteObject id="service" destination="planservice">
              <mx:method name="cargoPositionList" result="resultHandlerName(event);" fault="Alert.show(event.fault.faultString);"/>
          </mx:RemoteObject>
      private function resultHandlerName(e:ResultEvent):void
      here e.result will contain the return list from my component
      the problem here is I am not getting the values for the references to IcStorageNameDetail
      and my services-config.xml is
      <?xml version="1.0" encoding="UTF-8"?>
      <services-config>
          <services>
              <service
                 id="plan-service"
                 class="flex.messaging.services.RemotingService"
                 messageTypes="flex.messaging.messages.RemotingMessage">
                 <destination id="planservice">
      <default-channels>
                       <channel ref="seam-amf"/>
                  </default-channels>
              </service>
          </services>
          <channels>
                <channel-definition id="seam-amf" class="mx.messaging.channels.AMFChannel">
                         <endpoint
                             uri="http://{server.name}:{server.port}/toms/seam/resource/amf"
                             class="flex.messaging.endpoints.AMFEndpoint"/>
                         <properties>
                             <add-no-cache-headers>false</add-no-cache-headers>
                      </properties>
                </channel-definition>
          </channels>
      </services-config>
      and I didn't write any .as files corresponding to the entities
      please help me
      It's creating big pain for me
