18 Replies Latest reply on Feb 20, 2010 7:47 PM by Powered by Design
    RAM not showing up in system properties
    Powered by Design Level 4
      I have 3GB installed on my OLD Windows XP
      I have noticed lately that when I checked my System Properties it only says 2GB.
      But HWINFO32 shows 3GB
      I ran memtest86 to see if my ram was failing but it passed.
      Any ideas on why it only shows 2GB.
      I have an Nvidia 9800 1024MB graphics card if for some reason that is subtracting from my total.
      Thanks:  GLenn
        • 1. Re: RAM not showing up in system properties
          Harm Millaard Level 7
          Glenn,
          XP has always shown an amount less than what was actually installed. That is why a lot of people say that the maximum memory with XP is around 3.25 GB. That is not correct, it does see a maximum of 4 GB but reports 3.25 or some figure like that max. With 3 GB installed it will report something like 2.25 GB. Win7 does not have that confusing method, it reports the actual installed amount.
          Why then is XP reporting less memory? Because it deducts space used for video memory and stuff like this:
          I hope this explains it a bit.
          • 2. Re: RAM not showing up in system properties
            Thanks Harm.
            I have been having problems lately where a program will freeze then the [ Not Responding ] will come up next to the window.
            I was thinking it was a RAM issue but im not sure.
            I have updated my drivers and ran CCleaner and defraged my computer.
            Any ideas on what I might look at.
            I have PC Doctor and Microsoft Security and it says its clean.
            THanks:  Glenn
            • 3. Re: RAM not showing up in system properties
              Bill Gehrke Adobe Community Professional & MVP
              Have you tried my Premiere Pro Benchmark (PPBM4) to see how well your system is setup to run Premiere?
              • 4. Re: RAM not showing up in system properties
                YES Bill
                Im second to last at 329.6
                Its slow but my problem is a new thing.
                Glenn
                • 5. Re: RAM not showing up in system properties
                  How many processes do you have running before you start up Premiere?  Even though you have the only a single core system reported it looks to me like you have not tuned your system and have other programs stealing CPU cycles.
                  • 6. Re: RAM not showing up in system properties
                    Im sure its not tuned right but something is going wrong lately.
                    Here is the processes running at startup
                    and here is my start up
                    those checked are the only ones that are checked.
                    Just in the last couple days i have logged off and when I turned my computer back on it cant find the hard drive.
                    maybe my C: drive is going out ?
                    What would be the best way to test a drive ?
                    Glenn
                    • 7. Re: RAM not showing up in system properties
                      I wonder if it could be the CMOS battery ?
                      Its a 2005 computer with original battery.
                      Any way to test without taking out ?
                      GLenn
                      • 8. Re: RAM not showing up in system properties
                        Get rid of about 20 of those processes when you are editing.  Most of those startup items are unneccesary.  You are wasting over several hundred kilobytes of RAM out of that marginal 2 GB with all that unnecessary junk.
                        • 9. Re: RAM not showing up in system properties
                          Glenn,
                          I would disable all startup programs in CCleaner under Tools Startup. Do not delete them, just disable them. That allows you to easily reset them later if you so desire. Before starting PR, run Process Explorer again and check for any processes that are stealing CPU cycles. Investigate if you can kill them. If you can't kill them, try Suspend. A process like mDNSresponder or bonjourservice can easily be killed. In fact all Apple processes can be killed. Same with Java update scheduler.
                          • 10. Re: RAM not showing up in system properties
                            Thanks for the ideas.
                            Glenn
                            • 11. Re: RAM not showing up in system properties
                              the_wine_snob Level 9
                              Glenn,
                              I rely on the tips in this ARTICLE prior to any editing session.
                              Also, what does Start>Run>dxdiag show for your RAM and system?
                              • 12. Re: RAM not showing up in system properties
                                I will give that Article a good reading when my eyes are not so tired.   lol
                                Here is a screencap of dxdiag
                                I have 2 sticks of 512MB and 2 sticks at 1GB filling all 4 slots
                                This new problem is happening even while im not editing.
                                Thanks:  Glenn
                                • 13. Re: RAM not showing up in system properties
                                  For some reason your 512MB sticks are not showing up.  You might try reseating the modules.  If you have no luck getting them to show up pull them out of the system and see if they are dead and slowing down the system.  Let me know if they are not functioning.
                                  Harm, correct me if I am wrong.  Since on my XP system dxdiag shows the correct installed amout of memory it appears that his system is not seeing the other 1MB.
                                  When you ran memtest how much memory showed up?
                                  • 14. Re: RAM not showing up in system properties
                                    On my XP-Pro, my POST sees 4096, and dxdiag sees 3070. I do not have the +3GB Switch on this machine. I'll take a peek at the workstation with 4096 installed, and see what dxdiag reports.
                                    Glenn,
                                    When you go into the SetUp in the BIOS, what does it show for your RAM. Often, one has to set new RAM in the BIOS, as they are not automatically seen. Did you do that?
                                    • 15. Re: RAM not showing up in system properties
                                      Bill,
                                      I no longer have a system with XP on it, so I can't test it, but the fact that HWInfo sees all 4 sticks makes it very unlikely that the problem is sticks that became unseated. The next pages of the DXDIAG info would make that clear, but that requires Glenn to attach the file after saving it.
                                      • 16. Re: RAM not showing up in system properties
                                        I have saved the DXDIAG file and uploaded it.
                                        Does anyone think I should replace the CMOS battery ?
                                        I have not had any problems with my time not working or it turning off and no warnings ?
                                        Also, I have ordered 4 new 1GB Ram sticks so they are all the same speed.
                                        My 2 512's are the slowest and the new ones will be faster then the 2 1GB ones I have there now.
                                        I will pick up a can of air and clean out the unit too since its been over a year since I dusted it off.
                                        Thanks:  GLenn
                                        I will paste the info below too.
                                        System Information
                                        Time of this report: 2/17/2010, 10:58:48
                                               Machine name: BODY-2720725174
                                           Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.091208-2036)
                                                   Language: English (Regional Setting: English)
                                        System Manufacturer: Dell Inc.
                                               System Model: Dimension XPS
                                                       BIOS: Phoenix ROM BIOS PLUS Version 1.10 A07
                                                  Processor: Intel(R) Pentium(R) 4 CPU 3.40GHz (2 CPUs)
                                                     Memory: 2048MB RAM
                                                  Page File: 703MB used, 3239MB available
                                                Windows Dir: C:\WINDOWS
                                            DirectX Version: DirectX 9.0c (4.09.0000.0904)
                                        DX Setup Parameters: Not found
                                             DxDiag Version: 5.03.2600.5512 32bit Unicode
                                        DxDiag Notes
                                          DirectX Files Tab: No problems found.
                                              Display Tab 1: No problems found.
                                                Sound Tab 1: No problems found.
                                                  Music Tab: No problems found.
                                                  Input Tab: No problems found.
                                                Network Tab: No problems found.
                                        DirectX Debug Levels
                                        Direct3D:    0/4 (n/a)
                                        DirectDraw:  0/4 (retail)
                                        DirectInput: 0/5 (n/a)
                                        DirectMusic: 0/5 (n/a)
                                        DirectPlay:  0/9 (retail)
                                        DirectSound: 0/5 (retail)
                                        DirectShow:  0/6 (retail)
                                        Display Devices
                                                Card name: NVIDIA GeForce 9800 GT
                                             Manufacturer: NVIDIA
                                                Chip type: GeForce 9800 GT
                                                 DAC type: Integrated RAMDAC
                                               Device Key: Enum\PCI\VEN_10DE&DEV_0605&SUBSYS_0606196E&REV_A2
                                           Display Memory: 1024.0 MB
                                             Current Mode: 1600 x 900 (32 bit) (60Hz)
                                                  Monitor: Dell S2209W(Digital)
                                          Monitor Max Res: 1920,1080
                                              Driver Name: nv4_disp.dll
                                           Driver Version: 6.14.0011.9621 (English)
                                              DDI Version: 9 (or higher)
                                        Driver Attributes: Final Retail
                                        Driver Date/Size: 1/11/2010 20:03:33, 6359168 bytes
                                              WHQL Logo'd: Yes
                                          WHQL Date Stamp: n/a
                                                      VDD: n/a
                                                 Mini VDD: nv4_mini.sys
                                            Mini VDD Date: 1/11/2010 20:03:33, 10276768 bytes
                                        Device Identifier: {D7B71E3E-4545-11CF-4B5F-0D2603C2CB35}
                                                Vendor ID: 0x10DE
                                                Device ID: 0x0605
                                                SubSys ID: 0x0606196E
                                              Revision ID: 0x00A2
                                              Revision ID: 0x00A2
                                              Video Accel: ModeMPEG2_C ModeMPEG2_D
                                        Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                           {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                           {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                 Registry: OK
                                             DDraw Status: Enabled
                                               D3D Status: Enabled
                                               AGP Status: Enabled
                                        DDraw Test Result: Not run
                                        D3D7 Test Result: Not run
                                        D3D8 Test Result: Not run
                                        D3D9 Test Result: Not run
                                        Sound Devices
                                                    Description: SB Audigy 2 ZS Audio [C8C0]
                                        Default Sound Playback: Yes
                                        Default Voice Playback: Yes
                                                    Hardware ID: PCI\VEN_1102&DEV_0004&SUBSYS_20061102&REV_04
                                                Manufacturer ID: 1
                                                     Product ID: 100
                                                           Type: WDM
                                                    Driver Name: ctaud2k.sys
                                                 Driver Version: 6.00.0001.1241 (English)
                                                    WHQL Logo'd: Yes
                                                  Date and Size: 4/10/2007 03:20:38, 520488 bytes
                                                    Other Files:
                                                Driver Provider: Creative
                                                 HW Accel Level: Full
                                                      Cap Flags: 0xF5F
                                            Min/Max Sample Rate: 4000, 192000
                                        Static/Strm HW Mix Bufs: 64, 61
                                        Static/Strm HW 3D Bufs: 64, 61
                                                      HW Memory: 0
                                               Voice Management: Yes
                                        EAX(tm) 2.0 Listen/Src: Yes, Yes
                                           I3DL2(tm) Listen/Src: No, No
                                        Sensaura(tm) ZoomFX(tm): No
                                                       Registry: OK
                                              Sound Test Result: Not run
                                        Sound Capture Devices
                                                    Description: AK5370
                                          Default Sound Capture: Yes
                                          Default Voice Capture: Yes
                                                    Driver Name: usbaudio.sys
                                                 Driver Version: 5.01.2600.5512 (English)
                                                  Date and Size: 4/13/2008 10:45:12, 60032 bytes
                                                      Cap Flags: 0x41
                                                   Format Flags: 0x444
                                          Default Sound Capture: No
                                          Default Voice Capture: No
                                                      Cap Flags: 0x41
                                                   Format Flags: 0xFFF
                                        DirectMusic
                                                DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
                                             DLS Version: 1.00.0016.0002
                                            Acceleration: Enabled
                                                   Ports: SB Audigy 2 ZS DirectMusic Synthesizer [C8C0], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
                                                          SB Audigy 2 ZS Audio [C8C0], Software (Kernel Mode), Output, DLS, Internal
                                                          Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                                                          SB Audigy 2 ZS Synth A [C8C0] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                                                          SB Audigy 2 ZS Synth B [C8C0] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                                                          SB Audigy 2 ZS MIDI IO [C8C0] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
                                                          Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
                                                          SB Audigy 2 ZS MIDI IO [C8C0] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
                                                          Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
                                                Registry: OK
                                        DirectInput Devices
                                              Device Name: Mouse
                                                 Attached: 1
                                            Controller ID: n/a
                                        Vendor/Product ID: n/a
                                                FF Driver: n/a
                                              Device Name: Keyboard
                                                 Attached: 1
                                            Controller ID: n/a
                                                FF Driver: n/a
                                              Device Name: USB Receiver
                                                 Attached: 1
                                            Controller ID: 0x0
                                        Vendor/Product ID: 0x046D, 0xC509
                                                FF Driver: n/a
                                                 Attached: 1
                                            Controller ID: 0x0
                                                FF Driver: n/a
                                                 Attached: 1
                                            Controller ID: 0x0
                                                FF Driver: n/a
                                              Device Name: Lycosa Keyboard
                                                 Attached: 1
                                            Controller ID: 0x0
                                        Vendor/Product ID: 0x1532, 0x0109
                                                FF Driver: n/a
                                                 Attached: 1
                                            Controller ID: 0x0
                                                FF Driver: n/a
                                        Poll w/ Interrupt: No
                                                 Registry: OK
                                        USB Devices
                                        + USB Root Hub
                                        | Vendor/Product ID: 0x8086, 0x265B
                                        | Matching Device ID: usb\root_hub
                                        | Service: usbhub
                                        | Driver: usbhub.sys, 4/13/2008 10:45:38, 59520 bytes
                                        | Driver: usbd.sys, 8/10/2004 04:00:00, 4736 bytes
                                        Gameport Devices
                                        + Intel(R) 82801 PCI Bridge - 244E
                                        | Matching Device ID: pci\ven_8086&dev_244e
                                        | Service: pci
                                        | Driver: pci.sys, 4/13/2008 10:36:44, 68224 bytes
                                        +-+ Creative Game Port
                                        | | Matching Device ID: pci\ven_1102&dev_7003&subsys_00401102
                                        | | Service: gameenum
                                        | | Driver: gameenum.sys, 4/13/2008 10:45:29, 10624 bytes
                                        PS/2 Devices
                                        + HID Keyboard Device
                                        | Matching Device ID: hid_device_system_keyboard
                                        | Service: kbdhid
                                        | Driver: kbdhid.sys, 4/13/2008 10:39:48, 14592 bytes
                                        | Driver: kbdclass.sys, 4/13/2008 10:39:47, 24576 bytes
                                        | Service: kbdhid
                                        + Terminal Server Keyboard Driver
                                        | Matching Device ID: root\rdp_kbd
                                        | Upper Filters: kbdclass
                                        | Service: TermDD
                                        | Driver: termdd.sys, 4/13/2008 16:13:20, 40840 bytes
                                        + HID-compliant mouse
                                        | Matching Device ID: hid_device_system_mouse
                                        | Service: mouhid
                                        | Driver: mouclass.sys, 4/13/2008 10:39:47, 23040 bytes
                                        | Driver: mouhid.sys, 8/10/2004 04:00:00, 12160 bytes
                                        + Terminal Server Mouse Driver
                                        | Matching Device ID: root\rdp_mou
                                        | Upper Filters: mouclass
                                        | Service: TermDD
                                        DirectPlay Service Providers
                                        DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                        DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                        DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                        DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
                                        Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
                                        IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
                                        Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
                                        Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
                                        DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
                                        DirectPlay Test Result: Not run
                                        Registry: OK
                                        DirectPlay Adapters
                                        DirectPlay8 Modem Service Provider: Intel(R) 537EP V9x DF PCI Modem
                                        DirectPlay8 Serial Service Provider: COM1
                                        DirectPlay8 TCP/IP Service Provider: Local Area Connection 3 - IPv4 -
                                        DirectPlay Voice Codecs
                                        Voxware VR12 1.4kbit/s
                                        Voxware SC06 6.4kbit/s
                                        Voxware SC03 3.2kbit/s
                                        MS-PCM 64 kbit/s
                                        MS-ADPCM 32.8 kbit/s
                                        Microsoft GSM 6.10 13 kbit/s
                                        TrueSpeech(TM) 8.6 kbit/s
                                        DirectPlay Lobbyable Apps
                                        Disk & DVD/CD-ROM Drives
                                              Drive: C:
                                        Free Space: 899.0 GB
                                        Total Space: 953.9 GB
                                        File System: NTFS
                                              Model: WDC WD1001FALS-00J7B0
                                              Drive: F:
                                        Free Space: 114.2 GB
                                        Total Space: 476.9 GB
                                        File System: NTFS
                                              Model: WDC WD5000AAKS-00YGA0
                                              Drive: G:
                                        Free Space: 154.0 GB
                                        Total Space: 305.2 GB
                                        File System: NTFS
                                              Model: WDC WD3200KS-00PFB0
                                              Drive: D:
                                              Model: HL-DT-ST CD-RW GCE-8483B
                                             Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 10:40:46, 62976 bytes
                                              Drive: E:
                                              Model: _NEC DVD+-RW ND-3450A
                                        System Devices
                                             Name: Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
                                        Device ID: PCI\VEN_8086&DEV_266F&SUBSYS_01761028&REV_03\3&172E68DD&0&F9
                                           Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 12:51:52, 3328 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (English), 4/13/2008 10:40:30, 24960 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 10:40:30, 96512 bytes
                                             Name: Intel(R) 82801FB/FBM SMBus Controller - 266A
                                        Device ID: PCI\VEN_8086&DEV_266A&SUBSYS_01761028&REV_03\3&172E68DD&0&FB
                                           Driver: n/a
                                             Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2662
                                        Device ID: PCI\VEN_8086&DEV_2662&SUBSYS_00000000&REV_03\3&172E68DD&0&E1
                                           Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 10:36:44, 68224 bytes
                                             Name: Intel(R) 82801FB/FBM PCI Express Root Port - 2660
                                        Device ID: PCI\VEN_8086&DEV_2660&SUBSYS_00000000&REV_03\3&172E68DD&0&E0
                                             Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
                                        Device ID: PCI\VEN_8086&DEV_265C&SUBSYS_01761028&REV_03\3&172E68DD&0&EF
                                           Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:36, 30208 bytes
                                           Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:36, 143872 bytes
                                           Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 16:12:08, 74240 bytes
                                           Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:38, 59520 bytes
                                           Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 16:11:54, 7168 bytes
                                             Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
                                        Device ID: PCI\VEN_8086&DEV_265B&SUBSYS_01761028&REV_03\3&172E68DD&0&EB
                                           Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:36, 20608 bytes
                                             Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
                                        Device ID: PCI\VEN_8086&DEV_265A&SUBSYS_01761028&REV_03\3&172E68DD&0&EA
                                             Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
                                        Device ID: PCI\VEN_8086&DEV_2659&SUBSYS_01761028&REV_03\3&172E68DD&0&E9
                                             Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
                                        Device ID: PCI\VEN_8086&DEV_2658&SUBSYS_01761028&REV_03\3&172E68DD&0&E8
                                             Name: Intel(R) 82801FR SATA AHCI Controller
                                        Device ID: PCI\VEN_8086&DEV_2652&SUBSYS_01761028&REV_03\3&172E68DD&0&FA
                                           Driver: C:\WINDOWS\system32\DRIVERS\iaStor.sys, 5.00.0001.1001 (English), 4/25/2005 08:28:14, 871040 bytes
                                             Name: Intel(R) 82801FB LPC Interface Controller - 2640
                                        Device ID: PCI\VEN_8086&DEV_2640&SUBSYS_00000000&REV_03\3&172E68DD&0&F8
                                           Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 10:36:42, 37248 bytes
                                             Name: Intel(R) 925X/XE PCI Express Root Port - 2585
                                        Device ID: PCI\VEN_8086&DEV_2585&SUBSYS_00000000&REV_04\3&172E68DD&0&08
                                             Name: Intel(R) 925X/XE Memory Controller Hub - 2584
                                        Device ID: PCI\VEN_8086&DEV_2584&SUBSYS_00000000&REV_04\3&172E68DD&0&00
                                           Driver: n/a
                                             Name: Intel(R) 82801 PCI Bridge - 244E
                                        Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_D3\3&172E68DD&0&F0
                                             Name: Intel(R) 537EP V9x DF PCI Modem
                                        Device ID: PCI\VEN_8086&DEV_1080&SUBSYS_10001028&REV_04\4&10416D21&0&18F0
                                           Driver: C:\WINDOWS\system32\DRIVERS\IntelC51.sys, 2.15.0025.0000 (English), 11/20/2003 14:13:40, 1232741 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\IntelC52.sys, 4.58.0005.0000 (English), 11/20/2003 14:14:28, 646825 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\IntelC53.sys, 2.15.0025.0000 (English), 11/20/2003 14:12:56, 59717 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\mohfilt.sys, 7.11.0000.0000 (English), 11/20/2003 14:12:42, 37048 bytes
                                           Driver: C:\WINDOWS\system32\intelmoh.dll, 1.00.0000.0000 (English), 11/20/2003 14:12:28, 172032 bytes
                                           Driver: C:\WINDOWS\system32\mhwt.dll, 1.00.0000.0000 (English), 11/20/2003 14:12:14, 53248 bytes
                                           Driver: C:\WINDOWS\system32\IntelCc2.dll, 2.02.0000.0002 (English), 11/20/2003 14:11:58, 32725 bytes
                                             Name: Broadcom NetXtreme Gigabit Ethernet
                                        Device ID: PCI\VEN_14E4&DEV_1677&SUBSYS_167714E4&REV_00\4&1D7EFF9E&0&00E0
                                           Driver: n/a
                                             Name: Creative Game Port
                                        Device ID: PCI\VEN_1102&DEV_7003&SUBSYS_00401102&REV_04\4&10416D21&0&09F0
                                           Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:29, 10624 bytes
                                             Name: OHCI Compliant IEEE 1394 Host Controller
                                        Device ID: PCI\VEN_1102&DEV_4001&SUBSYS_00101102&REV_04\4&10416D21&0&0AF0
                                           Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.5512 (English), 4/13/2008 10:46:18, 61696 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.5512 (English), 4/13/2008 10:46:18, 53376 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.5512 (English), 4/13/2008 10:51:25, 61824 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.5512 (English), 4/13/2008 10:51:25, 60800 bytes
                                           Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 05:46:40, 6400 bytes
                                             Name: Creative SB Audigy 2 ZS (WDM)
                                        Device ID: PCI\VEN_1102&DEV_0004&SUBSYS_20061102&REV_04\4&10416D21&0&08F0
                                           Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/13/2008 16:11:56, 4096 bytes
                                           Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/13/2008 16:12:42, 129536 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/13/2008 11:16:36, 141056 bytes
                                           Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:14, 60160 bytes
                                           Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 11:19:42, 146048 bytes
                                           Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/13/2008 10:45:16, 49408 bytes
                                           Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/13/2008 16:12:45, 23552 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 6.00.0001.1241 (English), 4/10/2007 03:19:30, 511272 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 6.00.0001.1241 (English), 4/10/2007 03:20:38, 520488 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 6.00.0001.1241 (English), 4/10/2007 04:59:04, 126760 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 6.00.0001.1241 (English), 4/10/2007 03:25:46, 14632 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 6.00.0001.1241 (English), 4/10/2007 05:00:24, 157480 bytes
                                           Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 6.00.0001.1241 (English), 4/10/2007 03:28:36, 92968 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 6.00.0001.1241 (English), 4/10/2007 03:29:10, 797992 bytes
                                           Driver: C:\WINDOWS\system32\drivers\haP16v2k.sys, 6.00.0001.1241 (English), 4/10/2007 03:31:18, 163112 bytes
                                           Driver: C:\WINDOWS\system32\drivers\haP17v2k.sys, 6.00.0001.1241 (English), 4/10/2007 03:32:06, 189736 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ha20x2k.sys, 5.12.0001.1241 (English), 4/10/2007 05:03:12, 1164072 bytes
                                           Driver: C:\WINDOWS\system32\drivers\pfmodnt.sys, 3.00.0000.0012 (English), 4/10/2007 03:32:34, 16168 bytes
                                           Driver: C:\WINDOWS\system32\ctdlang.dat, 11/25/2003 20:29:54, 127226 bytes
                                           Driver: C:\WINDOWS\system32\ctdnlstr.dat, 4/9/2007 11:24:30, 46273 bytes
                                           Driver: C:\WINDOWS\system32\ctstatic.dat, 4/9/2007 11:19:20, 313207 bytes
                                           Driver: C:\WINDOWS\system32\ctdaught.dat, 4/9/2007 11:19:20, 53932 bytes
                                           Driver: C:\WINDOWS\system32\ctzapxx.ini, 4/9/2007 11:55:14, 54 bytes
                                           Driver: C:\WINDOWS\system32\instwdm.ini, 4/9/2007 11:55:14, 97785 bytes
                                           Driver: C:\WINDOWS\system32\kill.ini, 10/2/2006 08:25:18, 307 bytes
                                           Driver: C:\WINDOWS\system32\CT1MGM.ROM, 2/25/2000 03:49:36, 1048576 bytes
                                           Driver: C:\WINDOWS\system32\CT2MGM.SF2, 9/22/1999 14:18:38, 2167684 bytes
                                           Driver: C:\WINDOWS\system32\default4.sfm, 1/3/2002 06:44:16, 59 bytes
                                           Driver: C:\WINDOWS\system32\default8.sfm, 1/3/2002 06:44:16, 59 bytes
                                           Driver: C:\WINDOWS\system32\default.sfm, 1/3/2002 06:44:16, 59 bytes
                                           Driver: C:\WINDOWS\Temp\ctpxinst.exe, , 0 bytes
                                           Driver: C:\WINDOWS\Temp\cttele.dll, , 0 bytes
                                           Driver: C:\WINDOWS\system32\COMMONFX.DLL, 6.00.0001.1241 (English), 4/18/2007 07:59:40, 98600 bytes
                                           Driver: C:\WINDOWS\system32\CTAUDFX.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:16, 546048 bytes
                                           Driver: C:\WINDOWS\system32\CTSBLFX.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:16, 560384 bytes
                                           Driver: C:\WINDOWS\system32\CTEAPSFX.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:18, 168192 bytes
                                           Driver: C:\WINDOWS\system32\CTEDSPFX.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:20, 280320 bytes
                                           Driver: C:\WINDOWS\system32\CTERFXFX.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:20, 94976 bytes
                                           Driver: C:\WINDOWS\system32\CTEDSPIO.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:22, 128768 bytes
                                           Driver: C:\WINDOWS\system32\CTEDSPSY.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:22, 323328 bytes
                                           Driver: C:\WINDOWS\system32\CTEXFIFX.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:24, 1317632 bytes
                                           Driver: C:\WINDOWS\system32\CT20XUT.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:26, 164608 bytes
                                           Driver: C:\WINDOWS\system32\CTHWIUT.DLL, 6.00.0001.1241 (English), 4/12/2007 07:10:26, 66816 bytes
                                           Driver: C:\WINDOWS\system32\regplib.exe, 4/9/2007 11:21:44, 48128 bytes
                                           Driver: C:\WINDOWS\system32\a3d.dll, 80.00.0000.0003 (English), 4/9/2007 11:32:58, 34816 bytes
                                           Driver: C:\WINDOWS\system32\ac3api.dll, 6.00.0001.1242 (English), 4/9/2007 11:32:46, 27648 bytes
                                           Driver: C:\WINDOWS\system32\ctosuser.dll, 6.00.0001.1241 (English), 4/9/2007 11:21:50, 137728 bytes
                                           Driver: C:\WINDOWS\system32\ctemupia.dll, 6.00.0001.1241 (English), 4/9/2007 11:24:06, 110080 bytes
                                           Driver: C:\WINDOWS\system32\piaproxy.dll, 6.00.0001.1241 (English), 4/9/2007 11:21:42, 81920 bytes
                                           Driver: C:\WINDOWS\system32\ctdproxy.dll, 6.00.0001.1241 (English), 4/9/2007 11:22:00, 76800 bytes
                                           Driver: C:\WINDOWS\system32\ctagent.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:30, 8704 bytes
                                           Driver: C:\WINDOWS\system32\ctasio.dll, 6.00.0001.1241 (English), 4/9/2007 11:22:02, 79872 bytes
                                           Driver: C:\WINDOWS\system32\ctedasio.dll, 6.00.0001.1241 (English), 4/9/2007 11:22:04, 50176 bytes
                                           Driver: C:\WINDOWS\system32\ct_oal.dll, 6.00.0001.1241 (English), 4/9/2007 11:22:04, 205312 bytes
                                           Driver: C:\WINDOWS\system32\OALInst.exe, 1.09.0009.0000 (English), 11/22/2006 23:55:48, 782336 bytes
                                           Driver: C:\WINDOWS\system32\ctpxinst.exe, 1.01.0000.0058 (English), 11/14/2006 08:01:30, 58104 bytes
                                           Driver: C:\WINDOWS\system32\AddCat.exe, 0.00.0000.0001 (English), 4/9/2007 10:25:36, 48400 bytes
                                           Driver: C:\WINDOWS\system32\CTAPO32.UDA, 4/10/2007 05:11:58, 8009 bytes
                                           Driver: C:\WINDOWS\system32\APOMgrH.dll, 1.00.0020.0001 (English), 4/12/2007 07:10:28, 105728 bytes
                                           Driver: C:\WINDOWS\system32\ctthxcal.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:24, 69632 bytes
                                           Driver: C:\WINDOWS\system32\CTxfiBtn.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:34, 35840 bytes
                                           Driver: C:\WINDOWS\system32\CTxfiSpk.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:34, 46592 bytes
                                           Driver: C:\WINDOWS\system32\Ct20xspi.dll, 6.00.0001.1242 (English), 4/9/2007 11:29:30, 10752 bytes
                                           Driver: C:\WINDOWS\system32\CTxfispi.exe, 6.00.0001.1242 (English), 4/9/2007 11:29:28, 934400 bytes
                                           Driver: C:\WINDOWS\system32\Ctxfihlp.exe, 6.00.0001.1241 (English), 4/9/2007 11:32:32, 19968 bytes
                                           Driver: C:\WINDOWS\system32\Ctxfireg.exe, 6.00.0001.1242 (English), 4/9/2007 11:29:30, 43520 bytes
                                           Driver: C:\WINDOWS\system32\devreg.dll, 6.00.0001.1242 (English), 4/9/2007 11:19:02, 48640 bytes
                                           Driver: C:\WINDOWS\system32\eaxac3.dll, 1.01.0002.0000 (English), 7/11/2001 01:51:00, 77824 bytes
                                           Driver: C:\WINDOWS\system32\killapps.exe, 1.00.0000.0001 (English), 4/9/2007 11:19:16, 10240 bytes
                                           Driver: C:\WINDOWS\system32\ctpres.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:24, 9216 bytes
                                           Driver: C:\WINDOWS\system32\inres.dll, 1.00.0009.0000 (English), 4/9/2007 11:33:38, 11776 bytes
                                           Driver: C:\WINDOWS\system32\ctdcres.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:20, 10240 bytes
                                           Driver: C:\WINDOWS\system32\enlocstr.exe, 4/9/2007 11:19:18, 5120 bytes
                                           Driver: C:\WINDOWS\system32\psconv.exe, 4/9/2007 11:32:32, 37888 bytes
                                           Driver: C:\WINDOWS\system32\readreg.exe, 6.00.0001.1241 (English), 4/9/2007 11:32:36, 38400 bytes
                                           Driver: C:\WINDOWS\system32\ctmmep.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:28, 12800 bytes
                                           Driver: C:\WINDOWS\system32\ctmmactl.dll, 1.00.0001.0122 (English), 6/16/2005 09:17:16, 71680 bytes
                                           Driver: C:\WINDOWS\system32\CTpcmcia.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:30, 56832 bytes
                                           Driver: C:\WINDOWS\system32\CTBurst.dll, 1.00.0000.0024 (English), 4/9/2007 11:33:50, 43520 bytes
                                           Driver: C:\WINDOWS\system32\ctscal.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:22, 78336 bytes
                                           Driver: C:\WINDOWS\system32\ctspkhlp.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:30, 45568 bytes
                                           Driver: C:\WINDOWS\system32\ctdc0000.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:20, 227840 bytes
                                           Driver: C:\WINDOWS\system32\ctdc0001.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:22, 335872 bytes
                                           Driver: C:\WINDOWS\system32\ctdcifce.dll, 6.00.0001.1241 (English), 4/9/2007 11:32:22, 131072 bytes
                                           Driver: C:\WINDOWS\system32\CtHelper.exe, 6.00.0001.1241 (English), 4/9/2007 11:32:32, 19456 bytes
                                           Driver: C:\WINDOWS\system32\sfman32.dll, 6.00.0001.1241 (English), 4/9/2007 11:21:48, 22528 bytes
                                           Driver: C:\WINDOWS\system32\sfms32.dll, 6.00.0001.1241 (English), 4/9/2007 11:21:46, 130048 bytes
                                           Driver: C:\WINDOWS\system32\data\CT0060W.DAT, 4/9/2007 11:19:28, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\ctd20x.dat, 4/9/2007 11:19:20, 26783 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEAPSW.DAT, 4/9/2007 11:19:36, 201502 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSP2W.DAT, 4/9/2007 11:19:58, 374041 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPHW.DAT, 4/9/2007 11:20:00, 348425 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPKW.DAT, 4/9/2007 11:19:58, 294775 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPLW.DAT, 4/9/2007 11:19:58, 294775 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPPW.DAT, 4/9/2007 11:20:00, 330665 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPTW.DAT, 4/9/2007 11:20:00, 270927 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPUW.DAT, 4/9/2007 11:20:00, 270927 bytes
                                           Driver: C:\WINDOWS\system32\data\CTEDSPW.DAT, 4/9/2007 11:19:50, 374041 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017AW.DAT, 4/9/2007 11:19:32, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017BW.DAT, 4/9/2007 11:19:34, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017CW.DAT, 4/9/2007 11:19:34, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017DW.DAT, 4/9/2007 11:19:34, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017EW.DAT, 4/9/2007 11:19:34, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017FW.DAT, 4/9/2007 11:19:34, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017GW.DAT, 4/9/2007 11:19:36, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP017HW.DAT, 4/9/2007 11:19:36, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP046AW.DAT, 4/9/2007 11:21:30, 263802 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP046BW.DAT, 4/9/2007 11:21:30, 263802 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP046CW.DAT, 4/9/2007 11:21:30, 263802 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP055AW.DAT, 4/9/2007 11:21:32, 264060 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0060W.DAT, 4/9/2007 11:19:28, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0061W.DAT, 4/9/2007 11:19:30, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0070W.DAT, 4/9/2007 11:19:38, 289409 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP073AW.DAT, 4/9/2007 11:21:32, 265966 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0073W.DAT, 4/9/2007 11:19:38, 289409 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0090W.DAT, 4/9/2007 11:19:38, 276738 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0091W.DAT, 4/9/2007 11:19:42, 275169 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0092W.DAT, 4/9/2007 11:19:40, 276738 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0095W.DAT, 4/9/2007 11:19:44, 274587 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0100W.DAT, 4/9/2007 11:19:28, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0101W.DAT, 4/9/2007 11:19:30, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0102W.DAT, 4/9/2007 11:19:30, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0103W.DAT, 4/9/2007 11:19:32, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0105W.DAT, 4/9/2007 11:19:32, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0150W.DAT, 4/9/2007 11:19:26, 232158 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0161W.DAT, 4/9/2007 11:19:40, 275427 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0162W.DAT, 4/9/2007 11:19:40, 276738 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0170W.DAT, 4/9/2007 11:19:32, 235259 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0191W.DAT, 4/9/2007 11:19:40, 275169 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0192W.DAT, 4/9/2007 11:19:40, 276738 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0221W.DAT, 4/9/2007 11:19:30, 236189 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0222W.DAT, 4/9/2007 11:19:30, 236189 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0230W.DAT, 4/9/2007 11:19:42, 277159 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0231W.DAT, 4/9/2007 11:19:42, 275816 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0232W.DAT, 4/9/2007 11:19:42, 277159 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0238W.DAT, 4/9/2007 11:19:42, 275517 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0240W.DAT, 4/9/2007 11:19:44, 319070 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0242W.DAT, 4/9/2007 11:19:46, 319730 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0243W.DAT, 4/9/2007 11:19:46, 318800 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0244W.DAT, 4/9/2007 11:19:46, 319730 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0245W.DAT, 4/9/2007 11:19:46, 318254 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0246W.DAT, 4/9/2007 11:19:48, 319730 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0249W.DAT, 4/9/2007 11:19:48, 318341 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0280W.DAT, 4/9/2007 11:19:48, 318254 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0320W.DAT, 4/9/2007 11:19:50, 318254 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0350W.DAT, 4/9/2007 11:19:50, 323640 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0352W.DAT, 4/9/2007 11:19:50, 321529 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0355W.DAT, 4/9/2007 11:19:54, 322194 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0358W.DAT, 4/9/2007 11:19:52, 321552 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0359W.DAT, 4/9/2007 11:19:52, 320622 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0360W.DAT, 4/9/2007 11:19:52, 320076 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0380W.DAT, 4/9/2007 11:19:54, 320076 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0400W.DAT, 4/9/2007 11:19:56, 319757 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0460W.DAT, 4/9/2007 11:21:28, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0462W.DAT, 4/9/2007 11:21:32, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0463W.DAT, 4/9/2007 11:21:28, 264060 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0464W.DAT, 4/9/2007 11:21:30, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0465W.DAT, 4/9/2007 11:21:30, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0466W.DAT, 4/9/2007 11:21:28, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0468W.DAT, 4/9/2007 11:21:30, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0469W.DAT, 4/9/2007 11:21:30, 264130 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0530L.DAT, 4/9/2007 11:20:44, 232116 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0530W.DAT, 4/9/2007 11:20:02, 321377 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0531L.DAT, 4/9/2007 11:21:28, 232116 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0531W.DAT, 4/9/2007 11:20:46, 321377 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0550W.DAT, 4/9/2007 11:21:28, 264388 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0600W.DAT, 4/9/2007 11:19:56, 319757 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0610W.DAT, 4/9/2007 11:19:56, 319757 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0669W.DAT, 4/9/2007 11:19:58, 319757 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0678W.DAT, 4/9/2007 11:21:32, 345761 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0679W.DAT, 4/9/2007 11:21:28, 345761 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0730W.DAT, 4/9/2007 11:21:30, 265966 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0760W.DAT, 4/9/2007 11:21:30, 263543 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0773W.DAT, 4/9/2007 11:21:32, 269402 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP0930W.DAT, 4/9/2007 11:21:32, 268778 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP1140W.DAT, 4/9/2007 11:19:22, 233684 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4620W.DAT, 4/9/2007 11:19:20, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4670W.DAT, 4/9/2007 11:19:22, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4760W.DAT, 4/9/2007 11:19:22, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4780W.DAT, 4/9/2007 11:19:24, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4790W.DAT, 4/9/2007 11:19:26, 232158 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4820W.DAT, 4/9/2007 11:19:38, 267599 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4830W.DAT, 4/9/2007 11:19:24, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4831W.DAT, 4/9/2007 11:19:24, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4832W.DAT, 4/9/2007 11:19:26, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4840W.DAT, 4/9/2007 11:19:26, 232158 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4850W.DAT, 4/9/2007 11:19:22, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4870W.DAT, 4/9/2007 11:19:22, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4871W.DAT, 4/9/2007 11:19:24, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4872W.DAT, 4/9/2007 11:19:24, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4875W.DAT, 4/9/2007 11:19:24, 233024 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4890W.DAT, 4/9/2007 11:19:26, 232158 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4891W.DAT, 4/9/2007 11:19:28, 232158 bytes
                                           Driver: C:\WINDOWS\system32\data\CTP4893W.DAT, 4/9/2007 11:19:28, 232158 bytes
                                           Driver: C:\WINDOWS\system32\data\CTPDXW.DAT, 4/9/2007 11:19:30, 235142 bytes
                                           Driver: C:\WINDOWS\system32\data\CTPM002W.DAT, 4/9/2007 11:19:22, 233684 bytes
                                           Driver: C:\WINDOWS\system32\data\cts20x.dat, 4/9/2007 11:19:20, 2091 bytes
                                           Driver: C:\WINDOWS\system32\data\CTXFIGM.RFX, 7/28/2006 01:31:44, 41320 bytes
                                           Driver: C:\WINDOWS\system32\data\CTXFIEM.RFX, 7/28/2006 01:31:42, 41788 bytes
                                           Driver: C:\WINDOWS\system32\data\CTXFICM.RFX, 7/28/2006 01:31:40, 41624 bytes
                                           Driver: C:\WINDOWS\system32\data\CTXFICBM.RFX, 6/22/2005 21:58:50, 7352 bytes
                                           Driver: C:\WINDOWS\system32\ctbas2w.dat, 4/9/2007 11:21:28, 149838 bytes
                                           Driver: C:\WINDOWS\system32\ctsbas2w.dat, 4/9/2007 11:19:44, 274587 bytes
                                           Driver: C:\WINDOWS\system32\SBAudigy.ico, 8/17/2001 03:42:28, 7406 bytes
                                           Driver: C:\WINDOWS\system32\Audigy.bmp, 11/13/2001 00:48:20, 1912 bytes
                                           Driver: C:\WINDOWS\system32\ctcoinst.dll, 3.00.0002.0039 (English), 4/9/2007 11:33:36, 86016 bytes
                                           Driver: C:\WINDOWS\system32\ctdvinst.dll, 0.05.0000.0039 (English), 4/9/2007 11:33:36, 163328 bytes
                                           Driver: C:\WINDOWS\system32\ctsfinst.dll, 1.00.0000.0005 (English), 6/30/2005 06:24:14, 121856 bytes
                                           Driver: C:\WINDOWS\system32\drivers\ctdvda2k.sys, 5.13.0001.0461 (English), 4/10/2007 03:21:06, 347128 bytes
                                           Driver: C:\WINDOWS\system32\CTAPO32.dll, 1.00.0000.0151 (English), 4/9/2007 10:25:04, 444928 bytes
                                           Driver: C:\WINDOWS\system32\ctppld.dll, 1.00.0000.0151 (English), 4/9/2007 10:25:26, 45568 bytes
                                           Driver: C:\WINDOWS\CTDVAUDY.CDF, 1/3/2005 03:18:12, 4958588 bytes
                                           Driver: C:\WINDOWS\CTDV10K1.CDF, 6/25/2004 01:47:10, 3377466 bytes
                                           Driver: C:\WINDOWS\CTDV10K2.CDF, 11/15/2001 06:25:52, 3735544 bytes
                                             Name: NVIDIA GeForce 9800 GT
                                        Device ID: PCI\VEN_10DE&DEV_0605&SUBSYS_0606196E&REV_A2\4&16EC1A1&0&0008
                                           Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 10276768 bytes
                                           Driver: C:\WINDOWS\system32\OpenCL.dll, 1.00.0000.0000 (English), 1/11/2010 20:03:33, 61440 bytes
                                           Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 6359168 bytes
                                           Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 1081344 bytes
                                           Driver: C:\WINDOWS\system32\nvcompiler.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 11632640 bytes
                                           Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 4104192 bytes
                                           Driver: C:\WINDOWS\system32\nvcuvenc.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 4077672 bytes
                                           Driver: C:\WINDOWS\system32\nvcuvid.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 2259560 bytes
                                           Driver: C:\WINDOWS\system32\nvdata.bin, 1/11/2010 20:03:33, 2283526 bytes
                                           Driver: C:\WINDOWS\system32\nvinfo.pb, 1/11/2010 20:03:33, 9047 bytes
                                           Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.9621 (English), 1/11/2010 20:03:33, 14458880 bytes
                                           Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 1/11/2010 20:03:33, 25699 bytes
                                           Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0052.0030 (English), 1/11/2010 20:03:33, 592488 bytes
                                           Driver: C:\WINDOWS\system32\nvcod.dll, 1.07.0008.0073 (English), 11/20/2009 18:34:54, 182888 bytes
                                           Driver: C:\WINDOWS\system32\nvcodins.dll, 1.07.0008.0073 (English), 1/11/2010 20:03:33, 182888 bytes
                                             Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
                                        Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_01761028&REV_00\4&10416D21&0&38F0
                                        DirectX Components
                                           ddraw.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 279552 bytes
                                        ddrawex.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 27136 bytes
                                           dxapi.sys: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 10496 bytes
                                            d3d8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 1179648 bytes
                                        d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 8192 bytes
                                            d3d9.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 1689088 bytes
                                           d3dim.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 436224 bytes
                                        d3dim700.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 824320 bytes
                                        d3dramp.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 590336 bytes
                                           d3drm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 350208 bytes
                                          d3dxof.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 47616 bytes
                                        d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 34816 bytes
                                           dplay.dll: 5.00.2134.0001 English Final Retail 8/10/2004 04:00:00 33040 bytes
                                          dplayx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 229888 bytes
                                        dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 23552 bytes
                                        dpwsock.dll: 5.00.2134.0001 English Final Retail 8/10/2004 04:00:00 42768 bytes
                                        dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 57344 bytes
                                        dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:17 29696 bytes
                                          dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:17 17920 bytes
                                           dpnet.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 375296 bytes
                                        dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:09:20 3072 bytes
                                        dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:09:19 3072 bytes
                                        dpvoice.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 212480 bytes
                                        dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:18 83456 bytes
                                          dpvvox.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 116736 bytes
                                          dpvacm.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 21504 bytes
                                        dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 35328 bytes
                                        dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 60928 bytes
                                        dpserial.dll: 5.00.2134.0001 English Final Retail 8/10/2004 04:00:00 53520 bytes
                                          dinput.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 158720 bytes
                                        dinput8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 181760 bytes
                                           dimap.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 44032 bytes
                                        diactfrm.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 394240 bytes
                                             joy.cpl: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:41 68608 bytes
                                           gcdef.dll: 5.01.2600.0000 English Final Retail 8/10/2004 04:00:00 76800 bytes
                                             pid.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:02 35328 bytes
                                        gameenum.sys: 5.01.2600.5512 English Final Retail 4/13/2008 10:45:29 10624 bytes
                                          dsound.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 367616 bytes
                                        dsound3d.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 1293824 bytes
                                          dswave.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 19456 bytes
                                           dsdmo.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 181248 bytes
                                        dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 71680 bytes
                                          dmusic.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 104448 bytes
                                          dmband.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 28672 bytes
                                        dmcompos.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 61440 bytes
                                           dmime.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 181248 bytes
                                        dmloader.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 35840 bytes
                                        dmstyle.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 105984 bytes
                                        dmsynth.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 103424 bytes
                                        dmscript.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 82432 bytes
                                          system.dll: 1.00.3705.6018 English Final Retail 4/19/2009 06:48:18 1179648 bytes
                                          system.dll: 1.01.4322.2443 English Final Retail 10/14/2009 02:03:04 1232896 bytes
                                           dx7vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 619008 bytes
                                           dx8vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 1227264 bytes
                                        dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 2113536 bytes
                                           mfc40.dll: 4.01.0000.6140 English Final Retail 8/10/2004 04:00:00 924432 bytes
                                           mfc42.dll: 6.02.4131.0000 English Final Retail 4/13/2008 16:11:56 1028096 bytes
                                        wsock32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 16:12:10 22528 bytes
                                        amstream.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:49 70656 bytes
                                        devenum.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:51 59904 bytes
                                          dxmasf.dll: 6.04.0009.1133 English Final Retail 4/13/2008 16:11:52 498742 bytes
                                        mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:56 35328 bytes
                                        mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/13/2008 16:12:42 148992 bytes
                                           msdmo.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:59 14336 bytes
                                          encapi.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:53 20480 bytes
                                            qasf.dll: 10.00.0000.3646 English Final Retail 8/10/2004 04:00:00 221184 bytes
                                            qcap.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:12:03 192512 bytes
                                             qdv.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:12:03 279040 bytes
                                            qdvd.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:12:03 386048 bytes
                                           qedit.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:12:03 562176 bytes
                                        qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 09:21:32 733696 bytes
                                          quartz.dll: 6.05.2600.5908 English Final Retail 11/27/2009 09:11:44 1291776 bytes
                                        strmdll.dll: 4.01.0000.3938 English Final Retail 8/26/2009 00:00:21 247326 bytes
                                        iac25_32.ax: 2.00.0005.0053 English Final Retail 4/13/2008 16:12:42 199680 bytes
                                          ir41_32.ax: 4.51.0016.0003 English Final Retail 4/13/2008 16:12:42 848384 bytes
                                        ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/13/2008 16:11:55 120320 bytes
                                        ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/13/2008 16:11:55 338432 bytes
                                        ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/13/2008 16:11:55 755200 bytes
                                        ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/13/2008 16:11:55 200192 bytes
                                        ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/13/2008 16:11:55 183808 bytes
                                           ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/13/2008 16:12:42 154624 bytes
                                        mswebdvd.dll: 6.05.2600.5857 English Final Retail 8/5/2009 01:01:48 204800 bytes
                                              ks.sys: 5.03.2600.5512 English Final Retail 4/13/2008 11:16:36 141056 bytes
                                          ksproxy.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 129536 bytes
                                          ksuser.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:56 4096 bytes
                                          stream.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:45:16 49408 bytes
                                        mspclock.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:39:50 5376 bytes
                                           mspqm.sys: 5.01.2600.5512 English Final Retail 4/13/2008 10:39:51 4992 bytes
                                        mskssrv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:39:52 7552 bytes
                                          swenum.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:39:53 4352 bytes
                                           mstee.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:39:50 5504 bytes
                                           ipsink.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 16384 bytes
                                        mpeg2data.ax: 6.05.2700.2180 English Final Retail 8/10/2004 04:00:00 62976 bytes
                                          ndisip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:22 10880 bytes
                                        streamip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:22 15232 bytes
                                        msvidctl.dll: 6.05.2700.2180 English Final Retail 8/10/2004 04:00:00 1616384 bytes
                                            slip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:24 11136 bytes
                                        nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:26 85248 bytes
                                        ccdecode.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:24 17024 bytes
                                          vbisurf.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 30208 bytes
                                           msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 09:11:44 17920 bytes
                                        kstvtune.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 61952 bytes
                                           ksxbar.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 43008 bytes
                                        kswdmcap.ax: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:42 91136 bytes
                                        vfwwdm32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 16:12:08 53760 bytes
                                        wstcodec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:24 19200 bytes
                                        wstdecod.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:10 50688 bytes
                                            msdv.sys: 5.03.2600.5512 English Final Retail 4/13/2008 10:46:10 51200 bytes
                                        DirectShow Filters
                                        WDM Streaming VBI Codecs:
                                        NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
                                        CC Decoder,0x00200000,2,1,,5.03.2600.5512
                                        WST Codec,0x00200000,1,1,,5.03.2600.5512
                                        DirectShow Filters:
                                        WMAudio Decoder DMO,0x00800800,1,1,,
                                        WMAPro over S/PDIF DMO,0x00600800,1,1,,
                                        WMSpeech Decoder DMO,0x00600800,1,1,,
                                        Canon G.726 DMO Decoder,0x00000000,1,1,,
                                        WMVideo Advanced Decoder DMO,0x00800001,1,1,,
                                        Mpeg4s Decoder DMO,0x00800001,1,1,,
                                        WMV Screen decoder DMO,0x00800001,1,1,,
                                        WMVideo Decoder DMO,0x00800001,1,1,,
                                        WMV9 Advanced Profile Decoder,0x00600800,1,1,,
                                        Mpeg43 Decoder DMO,0x00800001,1,1,,
                                        Mpeg4 Decoder DMO,0x00800001,1,1,,
                                        WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
                                        ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0005.2052
                                        Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.01.0001.0000
                                        Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        Gretech ASF Source Filter,0x00200000,0,1,GSFU.ax,
                                        ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0005.2052
                                        RealPlayer Video Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0447
                                        Gretech MPEG Source Filter,0x00200000,0,1,GSFU.ax,
                                        CT Upsampler filter,0x00100000,1,1,Upsample.ax,2.00.0000.0003
                                        ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0005.2052
                                        Creative Wave Writer,0x00200000,1,0,WavWrite.ax,3.00.0003.0000
                                        WST Renderer,0x00800000,1,1,WSTRenderer.ax,6.05.2700.2180
                                        DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
                                        Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,3.00.0000.0000
                                        Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.5908
                                        WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
                                        Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,3.00.0000.0000
                                        Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
                                        AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.5908
                                        BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0004.0000
                                        WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.5908
                                        Sonic Audio Depth Converter (Symphony),0x00200000,1,1,AudioDepthConverterS.ax,5.00.0000.0001
                                        Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
                                        "MainConcept (Adobe2) AAC Decoder",0x00600000,1,1,ad2daac.ax",
                                        Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
                                        RealVideo Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0002
                                        "MainConcept (Adobe2) MPEG Splitter",0x005fffff,1,2,ad2mcspmpeg.ax",
                                        "MainConcept (Adobe2) MPEG Audio Decoder",0x005fffff,1,1,ad2mcdsmpeg.ax",
                                        "MainConcept (Adobe2) MPEG Video Decoder",0x005fffff,1,1,ad2mcdsmpeg.ax",
                                        "MainConcept (Adobe2) MPEG Encoder",0x00200000,2,1,ad2mcesmpeg.ax",
                                        "MainConcept (Adobe2) MPEG Video Encoder",0x00200000,1,1,ad2mcevmpeg.ax",
                                        "MainConcept (Adobe2) MPEG Audio Encoder",0x00200000,1,1,ad2mceampeg.ax",
                                        "MainConcept (Adobe2) MPEG Multiplexer",0x00200000,1,1,ad2mcmuxmpeg.ax",
                                        Creative Still Picture MPEG1 Splitter,0x00600000,1,2,CTspf.ax,1.00.0003.0000
                                        AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
                                        DvPlayTee,0x00200000,1,2,DXDVSupport.dll,4.02.0001.0000
                                        WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.02.0000.0000
                                        StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2700.2180
                                        WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5908
                                        Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
                                        WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
                                        SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
                                        Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
                                        MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.5908
                                        SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
                                        Essien R&D MPEG Writer Filter,0x00200000,2,0,mpgfiltr.ax,2.05.0001.0000
                                        VBI Codec,0x00600000,1,4,VBICodec.ax,6.05.2700.2180
                                        MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
                                        MPC - MPEG-2 Video Decoder (Gabest),0x00500001,1,1,Mpeg2DecFilter.ax,1.01.0796.0000
                                        MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.5512
                                        WAV Dest,0x00200000,0,0,viscomwave.dll,9.00.0000.0000
                                        ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
                                        Gretech Video Filter,0x00200000,1,1,GVF.ax,
                                        Canon MDP Motion-JPEG Decoder,0x00200001,1,1,CanonMDPMJPEGDecoder.ax,2.05.0000.0005
                                        WMS Filter,0x00400000,0,1,CTWMSFLT.DLL,1.12.0001.0000
                                        FLV Splitter,0x00800001,1,1,FLVSplitter.ax,1.05.0000.0318
                                        Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5908
                                        MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.5908
                                        _ VSO Preview Filter,0x00200000,0,1,VsoVprev.ax,3.00.0000.0036
                                        Gretech OGG2 Source Filter,0x00200000,0,1,GSFU.ax,
                                        WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.0000.0484
                                        File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
                                        Gretech Theora Source Filter,0x00200000,0,1,GSFU.ax,
                                        Gretech FLV Source Filter,0x00200000,0,1,GSFU.ax,
                                        WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
                                        DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
                                        Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
                                        Sonic RTStreamSink (Symphony),0x00200000,1,0,RTStreamSinkS.ax,5.00.0000.0001
                                        Canon Actual Data Length Setter,0x00200000,1,1,CanonActualDataLengthSetter.ax,2.04.0000.0005
                                        Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
                                        Canon Custom Resizer SaveMode,0x00200000,1,1,CanonDESResizer.ax,2.05.0000.0006
                                        Haali Media Splitter,0x00800001,0,1,splitter.ax,1.08.0122.0018
                                        Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.08.0122.0018
                                        Canon Resizer,0x00200000,1,1,CanonResizer.ax,2.04.0000.0006
                                        WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,5.00.0000.0000
                                        Gretech AsfEx Source Filter,0x00200000,0,1,GSFU.ax,
                                        Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0000.0004
                                        Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,3.00.0000.0000
                                        Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
                                        NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        FLAC Audio Decoder,0x00600014,1,1,flac.ax,1.00.0000.0000
                                        CT PDP filter,0x00100000,1,1,PDP.ax,1.00.0000.0000
                                        ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.5908
                                        Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
                                        Gretech AVI Source Filter,0x00200000,0,1,GSFU.ax,
                                        Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.5908
                                        Gretech Network(OGG) Filter,0x00200000,0,1,GNF.ax,
                                        Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2700.2180
                                        PushSource Bitmap Filter,0x00200000,0,2,PushSource.ax,
                                        Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.5512
                                        Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.5908
                                        WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
                                        Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.5908
                                        Sonic MPEG Non-Pro Audio Decoder (Symphony),0x00200000,1,1,SonicMPEGAudioS.DLL,2.05.0004.1403
                                        Haali Video Renderer,0x00200000,1,0,dxr.dll,
                                        RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.0001.0002
                                        Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,3.00.0001.0000
                                        CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
                                        WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3646
                                        Gretech Audio Filter,0x00200000,1,1,GAF.ax,
                                        FLV4 Video Decoder,0x00400000,1,1,FLVSplitter.ax,1.05.0000.0318
                                        CBVA Filter,0x00200000,1,1,CBVAFilter.dll,5.01.2700.2180
                                        WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
                                        Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,3.00.0001.0000
                                        Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
                                        File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
                                        "MainConcept (Adobe2) AAC Encoder",0x00100000,1,1,ad2eaac.ax",
                                        Canon Image Rotation Filter 1.1,0x00200000,1,1,CanonRotateFilter.dll,1.01.0000.0004
                                        Sonic MPEG Video Decoder (Symphony),0x00200000,2,1,SonicMPEGVideoS.DLL,2.05.0004.1041
                                        Gretech Network(FLV) Filter,0x00200000,0,1,GNF.ax,
                                        Gretech OGG Source Filter,0x00200000,0,1,GSFU.ax,
                                        Gretech Network(AVI) Filter,0x00200000,0,1,GNF.ax,
                                        Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.08.0122.0018
                                        Adobe PSI Parser,0x00200000,0,0,PSIParser.dll,
                                        WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        Canon G.726 Decoder,0x00800000,1,1,CanonG726Decoder.ax,1.00.0000.0003
                                        WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
                                        DirectVobSub,0x00200000,2,1,VSFilter.dll,1.01.0796.0000
                                        RealAudio Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0002
                                        Gretech MKV Source Filter,0x00200000,0,1,GSFU.ax,
                                        DirectVobSub (auto-loading version),0x00800002,2,1,VSFilter.dll,1.01.0796.0000
                                        WAV Dest,0x00000000,0,0,,
                                        DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.5512
                                        Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.5512
                                        Canon Motion-JPEG Decoder,0x00200001,1,1,CanonMJPEGDecoder.ax,2.05.0000.0005
                                        Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.08.0122.0018
                                        CT CMSS3 filter,0x00100000,1,1,CMSS3.ax,3.00.0000.0002
                                        AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.5908
                                        .RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
                                        Canon Text Source Filter,0x00200000,0,1,CanonTextSourceFilter.ax,2.05.0000.0012
                                        FLAC Audio Filter,0x00600014,0,0,flac.ax,1.00.0000.0000
                                        WST Pager,0x00800000,1,1,WSTPager.ax,6.05.2700.2180
                                        WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
                                        MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.5512
                                        DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
                                        RealPlayer Transcode Filter,0x00600000,0,0,rdsf3260.dll,6.00.0013.0447
                                        Creative MP3 Source Filter,0x00400000,0,1,CTMP3SFT.DLL,1.00.0010.0000
                                        Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
                                        Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
                                        Gretech Network(SHOUTcast) Filter,0x00200000,0,1,GNF.ax,
                                        Push Audio Filter,0x00200000,0,1,PushAudio.ax,
                                        ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0005.2052
                                        Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0000.0002
                                        ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
                                        9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
                                        Gretech Network(GOM) Filter,0x00200000,0,1,GNF.ax,
                                        Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.5512
                                        Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.5512
                                        Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,3.00.0003.0000
                                        WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
                                        MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2700.2180
                                        WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        FLV Source,0x00600001,0,0,FLVSplitter.ax,1.05.0000.0318
                                        StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2700.2180
                                        Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
                                        Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,3.00.0003.0000
                                        Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.5512
                                        RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0013.0447
                                        AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5908
                                        Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        Gretech MP4 Source Filter,0x00200000,0,1,GSFU.ax,
                                        AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.5908
                                        TS Strider,0x00200000,1,1,TSStrider.dll,1.01.0004.0021
                                        Dump,0x00200000,1,0,DvFileWriter.prm,4.02.0001.0000
                                        QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.5908
                                        Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
                                        MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
                                        Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.5908
                                        File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.5908
                                        XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
                                        Canon WAV Dest,0x00200000,0,0,CanonWavDest.ax,2.04.0000.0004
                                        WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01.0000.0323
                                        Sonic Cinemaster MPEG Splitter (Symphony),0x00200000,1,2,SonicMPEGSplitterS.dll,1.00.0000.0103
                                        NVF Filter,0x00400000,0,1,CTNVFFLT.DLL,1.00.0000.0000
                                        ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0005.2052
                                        DirectShow Tap (Symphony),0x00200000,1,1,DirectShowTapS.ax,5.00.0000.0001
                                        TSSourcePush,0x00200000,0,1,TSSourcePush.dll,
                                        RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00.0001.0002
                                        AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
                                        Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.5908
                                        File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.5908
                                        File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.5908
                                        WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        Canon Motion-JPEG Encoder,0x00200000,1,1,CanonMJPEGEncoder.ax,2.04.0000.0004
                                        Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,3.00.0001.0000
                                        WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        Haali Video Sink,0x00200000,1,0,splitter.ax,1.08.0122.0018
                                        Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
                                        Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.5908
                                        MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.5908
                                        psWav Dest,0x00200000,0,0,psWavDes.ax,1.01.0000.0002
                                        "MainConcept (Adobe2) H.264/AVC Decoder",0x00600000,1,1,ad2dsh264.ax",
                                        "MainConcept (Adobe2) H.264 Encoder",0x00200000,2,1,ad2esh264.ax",
                                        "MainConcept (Adobe2) H.264/AVC Video Encoder",0x00200000,1,1,ad2evh264.ax",
                                        Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
                                        Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
                                        WDM Streaming Tee/Splitter Devices:
                                        Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.5512
                                        WDM Streaming Data Transforms:
                                        Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
                                        Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.5512
                                        Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.5512
                                        Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
                                        Video Compressors:
                                        MSScreen encoder DMO,0x00600800,1,1,,
                                        WMVideo9 Encoder DMO,0x00600800,1,1,,
                                        WMVideo Advanced Encoder DMO,0x00600800,1,1,,
                                        MSScreen 9 encoder DMO,0x00600800,1,1,,
                                        DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
                                        ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0005.2052
                                        Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
                                        MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.5908
                                        Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
                                        Audio Compressors:
                                        WM Speech Encoder DMO,0x00600800,1,1,,
                                        WMAudio Encoder DMO,0x00600800,1,1,,
                                        IAC2,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.5908
                                        Audio Capture Sources:
                                        AK5370          ,0x00200000,0,0,qcap.dll,6.05.2600.5512
                                        SB Audigy 2 ZS Audio [C8C0],0x00200000,0,0,qcap.dll,6.05.2600.5512
                                        Midi Renderers:
                                        Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.5908
                                        Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        SB Audigy 2 ZS MIDI IO [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        SB Audigy 2 ZS Synth A [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        SB Audigy 2 ZS Synth B [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        WDM Streaming Capture Devices:
                                        SB Audigy 2 ZS MIDI IO [C8C0],0x00200000,2,2,,5.03.2600.5512
                                        SB Audigy 2 ZS Audio [C8C0],0x00200000,3,2,,5.03.2600.5512
                                        USB Audio Device,0x00200000,1,1,,5.03.2600.5512
                                        WDM Streaming Rendering Devices:
                                        SB Audigy 2 ZS DirectMusic Synthesizer [C8C0],0x00200000,1,1,,5.03.2600.5512
                                        SB Audigy 2 ZS Synth A [C8C0],0x00200000,1,1,,5.03.2600.5512
                                        SB Audigy 2 ZS Synth B [C8C0],0x00200000,1,1,,5.03.2600.5512
                                        BDA Rendering Filters:
                                        BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
                                        Multi-Instance Capable VBI Codecs:
                                        BDA Transport Information Renderers:
                                        MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2700.2180
                                        WDM Streaming Mixer Devices:
                                        Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
                                        BDA CP/CA Filters:
                                        Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2700.2180
                                        Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2700.2180
                                        XDS Codec,0x00200000,0,0,encdec.dll,6.05.2700.2180
                                        WDM Streaming Communication Transforms:
                                        Audio Renderers:
                                        SB Audigy 2 ZS Audio [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.5908
                                        Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        DirectSound: SB Audigy 2 ZS Audio [C8C0],0x00200000,1,0,quartz.dll,6.05.2600.5908
                                        WDM Streaming System Devices:
                                        SB Audigy 2 ZS Synth A [C8C0],0x00200000,11,2,,5.03.2600.5512
                                        SB Audigy 2 ZS Audio [C8C0],0x00200000,13,2,,5.03.2600.5512
                                        BDA Receiver Component:
                                        BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
                                        • 17. Re: RAM not showing up in system properties
                                          Harm Millaard Level 7
                                          Glenn,
                                          Indeed strange that DXDIAG shows only 2 GB RAM. Can you try CPU-Z and tell what it shows? Go to the Memory tab and check each slot.
                                          You have the SB Audigy installed. I hope you limited yourself to the driver only and did not install the rest of the SB crap.
                                          Why have you installed FFDShow, Haali and Matroska? What is the use of Gretech?
                                          • 18. Re: RAM not showing up in system properties
                                            Powered by Design Level 4
                                            I got new faster RAM.
                                            I got 4 new DDR2PC2-6400 all the same.
                                            After installing it still showed only 2GB in the windows system properties.
                                            After doing some reading online some people have enabled something called the 3GB Switch to see more ram for certian programs.
                                            After modifing my boot.ini file it now shows 3GB like before.
                                            I wonder if some update i did changed something to make it only see 2GB.
                                            CPU-Z shows all 4GB there just fine.
                                            Also when I boot up and check my BIOS it shows all four there too.
                                            When I ran CCleaner it used to only show 2GB but now shows 3GB also.
                                            I only installed the Sound Blaster Audio drivers.
                                            Im not sure on the other stuff, I might have installed it with some of my camera programs, not sure.
                                            Got allot of junk on here that I wont install on my editing rig when I build it after our move to new house.
                                            Here is the screen shots of CPU-Z and DXDIAG
                                            Here is the file I changed to make it work.
                                            Thanks:  Glenn
                                            Enable the 3GB switch on Windows XP
                                            • Right-click My Computer. Click Properties.
                                            • In the System Properties dialog box, click the Advanced tab.
                                            • On the Advanced tab, under Startup and Recovery, click  Settings.
                                            • In the Startup and Recovery dialog box, under System startup,  click Edit. The Windows boot.ini file will be opened in Microsoft®  Notepad.
                                            • Create a backup copy of the boot.ini file. Note: Boot.ini files  may vary from computer to computer.
                                              Select the following line in  the boot.ini file:
                                            multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP  Professional" /fastdetect
                                            • Press Ctrl+C to copy the line and then press Ctrl+V to paste it  immediately below the original line.
                                              Note: Your text string may be  different from the text string in this solution, so be sure to copy the  text string from your boot.ini file, and not the text string included  here.
                                              Modify the copied line to include “ /3GB”, as shown in the  following example:
                                            multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP  Professional 3GB" /3GB /fastdetect
                                            Note: Do not overwrite any existing lines.
                                            • Save and close the boot.ini file.
                                            • Click OK to close each dialog box.
                                            • Restart your computer.
                                            • During startup, select the 3GB option. If you do not select the  3GB option, the system will default to the 2GB total memory setting.
                                            Note: If problems occur during startup, you may need to update some  of your drivers.
