5 Replies Latest reply on Feb 15, 2010 2:52 PM by nealeh
    File Accepted in Premiere Elements 8
    mustang351w
      I plan on getting a Canon Rebel T2i camera which also does video. It saves the files in the MOV format whish uses H264 compression. Its has 3 frame rates, of which I will be using 1920x1080 30P. Is Premiere Elements 8 setup to import these files? I suspect the compression rate is quite large on the video from these cameras. Also do these files easily burn onto a Blu Ray disc for play on these home players? Thirdly can the 30P file be converted down to the HDV standard to archive onto tape with this format?
