7 Replies Latest reply on Feb 15, 2010 5:38 PM by kglad
    Load external SWF's help
    jynx19
      I am using this thumbnail gallery attached but instead of loading images through the xml I want to load external SWF'S. I also want to be able to control each SWF loaded in individually apparently in order to do that I need to give the container different instance names..however I don't know how to extend the code inorder to achieve this..can anyone help?
        • 1. Re: Load external SWF's help
          you can reference a loaded swf by using the target movieclip's instance name AFTER loading is complete.  if you don't understand how that applies to your code, post (only) the code that loads swfs.
          • 2. Re: Load external SWF's help
            jynx19 Level 1
            Hello Kglad,
            Thank you for the swift reply, I don't know how to apply this to my code. At the moment it loads in images but it will load in external SWF's I pressume this is the section of code relevant;
            function thumbnailer(k){
            total_thumbs = _global.total;
            var container = thumbnail_mc.createEmptyMovieClip("th"+k,thumbnail_mc.getNextHighestDepth());
            container._visible=false;
            container._alpha=0;
            var image = container.createEmptyMovieClip("img", container.getNextHighestDepth());
            tlistener = new Object();
            tlistener.onLoadInit = function(target_mc) {
              target_mc.pictureValue = k;
              target_mc.onRollOver = function() {
               this._alpha = 50;
              target_mc.onRollOut = function() {
               this._alpha = 100;
            image_mcl = new MovieClipLoader();
            image_mcl.addListener(tlistener);
            image_mcl.loadClip(thumbnails[k], "thumbnail_mc.th"+k+".img");
            • 3. Re: Load external SWF's help
              to control the swf at thumbnails[k], you reference:
              thumbnail_mc["th"+k]
              from the timeline that contains thumbnail_mc.
              in addition, you should fix your code:
              container._alpha=0;
              image_mcl.loadClip(thumbnails[k], image);
                 this._alpha = 50;
                 this._alpha = 100;
              • 4. Re: Load external SWF's help
                jynx19 Level 1
                kglad thank you for your help, I don't mean
                to be a pain but do you mind explaining what is meant by referencing from the timeline?
                Thanks for your paitence
                • 5. Re: Load external SWF's help
                  if you attach code to the same timeline that contains the above code, use:
                  if you attached code to a child movieclip of the timeline with the above code, use:
                  parent.thumbnail_mc["th"+k];
                  • 6. Re: Load external SWF's help
                    jynx19 Level 1
                    In that case i'd need to use; thumbnail_mc["th"+k]
                    the only thing im confused about now is if I'm loading in multiple SWF's using ; thumbnail_mc["th"+k] would that not apply the code to all the SWF's where as i'd want to target one?
                    Thanks for all your help, learning slowly but surely
                    • 7. Re: Load external SWF's help
                      you'll have a distinct target and distinct swf for each k.
