6 Replies Latest reply on Mar 9, 2010 9:49 AM by saariko
    Flash CS4: Unable to perform Test Movie when working on an AIR file
    c0j Level 1
      I am starting to develop  an AIR application. After doing some code, I am able to test the AIR file from within Flash CS4. I then close the Movie Test and made some additional changes. I performed another Test Movie however nothing happens. If I restart Flash CS4, I am able to test the AIR file but not a second time.
      OS: Windows 7 64
      Flash CS4
      4GB RAM
      I have performed the following troubleshooting steps:
      1. Reset the configuration folder -> same issue
      2. Reset the Registry Key -> same issue
      3. Tested on Windows XP 32 (Same machine [dual-boot]) -> works
      4. Tested with a brand new FLA AIR file -> same issue
      5. If I convert the AIR file to a standard AS3 document -> able to to test with no issue
      Any suggestions or solutions will be most helpful.
