3 Replies Latest reply on Aug 4, 2011 6:25 AM by ogerou_screenname
    Data tips in column chart - show strange numbers
    martinjconnolly Level 1
      Hi all
      quite often the data tip on a column chart shows loads of decimal places, even if that is not present in the data that it is representing. My application has data stored to only 3 decimal places but the chart often shows 12 (if I count them right) in the data tip. Why does this happen and is writing my own data tip function the only solution?
        • 1. Re: Data tips in column chart - show strange numbers
          Yogi_ACE Level 2
          Till the time you found correct solution for this, you can use NumberFormatter and set precision value for the number.
          e.g.
          var value:* = 6.1649999999...;
          var _numFormatterObj:NumberFormatter = new NumberFormatter();
          _numFormatterObj.precision = 3;
          var num:String = _numFormatterObj.format(value);
          Regards,
          Yogesh
          • 2. Re: Data tips in column chart - show strange numbers
            BrianIreland Level 1
            The above suggestion works fine, but you can also use:
            var:value: Number = int(yourNumber * 1000)/1000;
            or if using a string value first:
            var value:Number = int(Number(stringValue)*1000)/1000
            • 3. Re: Data tips in column chart - show strange numbers
              ogerou_screenname
              Hello,
              Sorry about resurecting an old post, but I'm having the same issue. My original numbers have unknow number of decimals, and when storing them in my ArrayCollection, I was originally using Math.round(myNumber*100)/100 to keep only 2 decimals. To my surprise, chart datatips show some numbers with 10 decimals (38.4899999999 for example).
              I switched to using Number(nfToVal.format(myNumber)), since I already use the same NumberFormatter to display those numbers in a datagrid.
              For info, nfToVal is:
              var nfToVal:NumberFormatter = new NumberFormatter();
              nfToVal.decimalSeparatorFrom=".";
              nfToVal.decimalSeparatorTo = ".";
              nfToVal.useNegativeSign="true";
              nfToVal.thousandsSeparatorFrom="";
              nfToVal.thousandsSeparatorTo="";
              nfToVal.precision="2";
              nfToVal.rounding="nearest";
              Problem still there! Numbers display correctly as strings after being formatted, but get decimals again when converted back to numbers ...
              Any hints ????
              Olivier
