0 Replies Latest reply on Feb 16, 2010 5:43 AM by CoreyRLucier
    [svn:fx-4.x] 14185: Merging 4.0.0 revision 14184 -> 4.x branch.
    CoreyRLucier Adobe Employee
      Revision: 14185
      Revision: 14185
      Author:   clucier@adobe.com
      Date:     2010-02-16 05:43:51 -0800 (Tue, 16 Feb 2010)
      Log Message:
      Remove all references to 'Flash XML Graphics" from compiler properties files.
      QE notes: None
      Doc notes: None
      Bugs: SDK-25505
      Reviewer: Pete F.
      Tests run: Checkin
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-25505
      Modified Paths:
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_da.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_de.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_es.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_fi.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_fr.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_it.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_ja.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_ko.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_nb.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_nl.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_pt.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_ru.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_sv.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_zh_CN.properties
          flex/sdk/branches/4.x/modules/compiler/src/java/flex2/compiler_zh_TW.properties
      Property Changed:
          flex/sdk/branches/4.x/build.xml
          flex/sdk/branches/4.x/frameworks/
