3 Replies Latest reply on Feb 16, 2010 12:01 PM by TerryGV
    wysiwyg question
    TerryGV
      Here is what I see in DW CS4:
      But here is what it shows on my site:
      http://www.vacation-rental-info.com
      I'm relatively new to this stuff but have a little knowledge.  I can't figure this out.
      TGV
        • 1. Re: wysiwyg question
          osgood_ Level 8
          It looks as though the links in the page to the css files may not be correct, any how the page is NOT picking up the css styles.
          Try changing this:
          <link href="../CSS_Files/VRI Layout_001.css" rel="stylesheet" type="text/css" />
          to:
          <link href="CSS_Files/VRI Layout_001.css" rel="stylesheet" type="text/css" />
          However looking at the page again the links to the css may be correct but line 7 in your code is incorrect:
          <meta http-equiv="Content-Type" content+"text/html; charset=utf-8" />
          it should be as below (Note the = sign after the second instance of 'content'. Above you have a + sign( where did that originate from?)
          <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
          • 2. Re: wysiwyg question
            TerryGV Level 1
            Dear Osgood,
            I checked and site is defined properly.
            I made your suggested changes below and it worked!
            TGV
            • 3. Re: wysiwyg question
              TerryGV Level 1
              I have no idea where the "+" came from.  All I can say is that maybe I was manually editing the file and pushed the shift key simultaneously as "+" shares "=" on the same key.  Weird.  Thanks again.
