1 Reply Latest reply on Feb 16, 2010 11:33 AM by shunithD
    how to get a portion of an object in front
    Jod55
      I'm using Illustrator CS3 and I have two objects.
      How can I get one part of the object on top of another object and the other part of it under the other object?
        • 1. Re: how to get a portion of an object in front
          shunithD Level 3
          I'm probably wrong but offhand you cant do it so simply. You have two options.
          Option 1:
          1/ Duplicate the object that will sandwhich the other... let's call them Object 1 and Object 2 respectively... into a separate layer or sub-layer
          2/ So, Object 1 is now duplicated. Move one instance so that it is on top of Object 2
          3/ Creating clipping masks, block out the relevant bits of Object 1 and you're done
          Option 2:
          The same first steps as in Option 1, then:
          1/ Delete the parts of Object 1 upper  and Object 1 lower that you don't want to show.
          In some cases, depending on what you're trying to do, one of the Object 1 avatars can remain intact...
