1 Reply Latest reply on Feb 24, 2010 6:31 PM by Mark C. Dahm
    Reconnecting to G Drive
      I recently bought a flash drive to put all of my pictures on. I moved all of the photos not thinking of the connection between them and Photoshop, now they are all disconnected. When I go into reconnect them it does not bring up Drive G as a place to reconnect the files too. I can import my pictures from my flash drive (G Drive) but is then saves them to a location on my C drive again. Is there a way to fix this without putting the pictures back on my C drive?
        • 1. Re: Reconnecting to G Drive
          Mark C. Dahm Adobe Employee
          In the reconnect missing files dialog, navigate to the G drive (click at the top where it says C), and select one of the files; the rest should then be found if you repeat the Reconnect Missing files command again, as long as they are in the same folder. You may need to reconnect at least one file from each sub folder on G, if you have more than one, to help the Reconnect command find them all.
