0 Replies Latest reply on Feb 16, 2010 1:53 PM by HansMuller
    [svn:fx-trunk] 14197: Merge 4.x revision 14151 to trunk.
    HansMuller Level 1
      Revision: 14197
      Revision: 14197
      Author:   hmuller@adobe.com
      Date:     2010-02-16 13:52:40 -0800 (Tue, 16 Feb 2010)
      Log Message:
      Merge 4.x revision 14151 to trunk.   Second try.
      Revised mirroring support for popups in DropDownList and ComboBox.
      UIComponent/invalidateLayoutDirection() now assumes that a component without an IVisualElement parent inherits a LTR coordinate system.
      PopUpAnchor uses MatrixUtil.getConcatenatedMatrix() - which concatenates UIComponent layoutMatrix - for layout computations and MatrixUtil.getConcatenatedComputedMatrix() to find the stage coordinates of a popup's origin.
      Sync'd MX ListBase/validateDisplayList(), which is a copy of UIComponent/validateDisplayList() with validateMatrix() changes made
      in the UIComponent version.
      QE notes: Full Mustella run was OK (thanks Joan!)
      Doc notes:
      Bugs:
      Reviewer: Jason
      Tests run:
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
      Property Changed:
          flex/sdk/trunk/
          flex/sdk/trunk/build.xml
